Old 08-03-2010, 04:56 PM   #1
GSTruck
GSTruck's Avatar
63 power steering
Just bought a 63 SWB fleetside and want to convert to power steering. I plan to install a 94 LT1 V8 so I will need power steering. Any suggestions what type box will interchange for the power steering upgrade?
GSTruck is offline   Reply With Quote
Old 08-03-2010, 06:49 PM   #2
Bugeyev8
Bugeyev8's Avatar
Re: 63 power steering
I believe 71-83 will fit, on the 63 I believe you just need the control arms and spindles as well as box and link assembly, there is a guy on here that sells the adaptor for the frame for the box
Good luck, please post some pics when you get started
Bugeyev8 is offline   Reply With Quote
Old 08-03-2010, 08:18 PM   #3
Heater63
Heater63's Avatar
Here you go:
http://67-72chevytrucks.com/vboard/s...d.php?t=394688
there are many other threads on this board too
control arms and spindles will be the same, you might need a different pitman arm.
You will need a adapter/reinforcing plate. CaptainFab is the "guy" on here that makes them. So does REZ engineering.com
292 + TKO500
Heater63 is offline   Reply With Quote
Old 08-04-2010, 12:05 AM   #4
Captainfab
60-66 Nut
Any truck based steering box from '69-'87 will work. However starting in about 1980-81 GM switched from inverted flare fittings to a metric sized fitting with an O-ring. So if you plan to use the power steering pump from the LT1, then It would make finding hoses easier if you used a box from a '81-'87 pickup or the Suburbans and crew cabs thru '91. The 4x4 boxes are basically identicle, but the sector shaft (output shaft) is different. So stay clear of those.
Old 08-04-2010, 11:10 AM   #5
GSTruck
GSTruck's Avatar
Would like to order the bracket. Let me know how to do so.
Old 08-05-2010, 11:13 PM   #6
Heater63
Heater63's Avatar
292 + TKO500
Old 08-05-2010, 11:15 PM   #7
Heater63
Heater63's Avatar
Look UP ^^^^^ where it says:
http://www.67-72chevytrucks.com/vboa...d.php?t=332923
292 + TKO500
