Junior Member
Dana 60 8 lug broke see pics
How bad do you think this is? I did not have the camera at the shop to get pics of the internals.
71 Suburban 350/700R4 Project Trixie 72 CHEVY,Highlander,SWB,396,T400 |
Re: Dana 60 8 lug broke see pics
Is the broken piece part of the spider pin? The only time I have ever seen one of those break was on a mini-spool. How does the case look where the pin goes into it?
Ray |
Junior Member
The pin goes down the middle but I have no idea what it is called. I have never had an issue with any of my 12 bolts so I have zero experience knowing what happened here.
Junior Member
It looks like the spider gear set up is what broke. Does this usually damage other parts?
Well there could be other damage, depending on where some of the metal bits went. Also, you need to inspect the bores in the differential case where the pin goes through.
Ray Last edited by raycow; 08-04-2010 at 11:17 AM. |
Junior Member
Anyone know of a reputable driveline shop in the Tyler, TX area? I have one I have used in the past but it is about 80 miles from me.
71 Suburban 350/700R4 Project Trixie 72 CHEVY,Highlander,SWB,396,T400 Last edited by BB72CHEVKT; 08-06-2010 at 04:59 PM. Reason: add info |
