Hey gang, does anyone have their power steering pump off at the moment that could give me the appropriate bolt measurements (thread-pitch x length) for the two that go into the block, next to the crank? I've got all the others, but I don't have a fist full of misc hardware to try in there at present.
Thanks ~Dan EDIT: Its the style with those two bolts and an arm that attaches to the motor mount. (307, original motor) Last edited by DjS71; 08-03-2010 at 09:49 PM. |
Grandpa in the rustmobile...
Re: Power Steering bracket hardware
I can take some pics of mine tomorow, Im not good at figuring out the size lol...dad can though.
(your talking about the bolts the hold the bracket to the block) ?
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
Aye, those ones. Thanks!
Ok, I just got home i'll go take one out and take a pic with the good camera...dads not home though...
Ps, its the same size bolt that goes in your intake manifold (non vortec)
The bolt threads are 3/8-16. I use bolts that are 2" long but the holes need to have the threads cleaned up as they will bottom out slightly. I believe that the factory bolts were 1 3/4" long but most bolts come in 1/2" increments so 2" is the closest that I could come up with.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
Rockin', thank you.
