Old 08-03-2010, 10:36 PM   #1
kev2809
low n' slo
kev2809's Avatar
How about this setup?
ive decided to rework my suspension a little bit, to get a few inches lower. it probably wont be until fall or winter until i get around to doing it but i want to get the parts and thinking out of the way now lol
i would like to do a setup like this...except instead of using a bridge bar on top to mount the bags, i would like to weld a top plate on top of the frame, then still offset a circle plate on the trailing arm like the pic below. this way, the ta will hit the frame, and i can get another 3" lower (the size of the collapsed bag). would this work?
67 1/2 ton Suburban - Project DRGNWGN. Build thread
-_--_--_ _________
_--_-_ -/____|__|__\__
,.,,,.,.,,.,|_O _______ O_]
kev2809 is offline   Reply With Quote
Old 08-03-2010, 11:41 PM   #2
blime81
Laid Lo
blime81's Avatar
Re: How about this setup?
You'd be boxing the frame I take it? Or at least near the upper plate?
Semper Fi,
Jeff
'72 C10 - lays frame
'07 Sand Rail - ecotec powered
'05 2500HD - tows stuff
'67 VW Bug - gas saver
'01 Jeep TJ - rock crawler
blime81 is offline   Reply With Quote
Old 08-04-2010, 06:05 AM   #3
kev2809
low n' slo
kev2809's Avatar
I could, near the upper plate. and gusset the bottom plate like the pic. I could have sworn I seen a setup like that...
-_--_--_ _________
Old 08-04-2010, 08:56 AM   #4
N2TRUX
Happy to be here
N2TRUX's Avatar
What your suggesting might work, but what you have pictured would be stronger.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 08-04-2010, 08:24 PM   #5
kev2809
low n' slo
kev2809's Avatar
i guess i could run it the same way in the pic, i just didnt want to add another bridge bar, but not a big deal. what size bar should i be looking for (square tubing)? i will be buying the plates from suicidedoors more than likely since i have ordered mostly everything else there. also, if i do it like the pic above, would i have to box in the frame in that area?
-_--_--_ _________
