Old 08-04-2010, 12:02 AM   #1
70chevyk10dlx
front drive shaft
how far can a stock 1970 k10 stepside front drive shaft extend safely from its stock position.. will it be capable of handleing a 6inch lift thanks joe
1970 k10 custom delux Bone stock except for the four inch lift kit
70chevyk10dlx is offline   Reply With Quote
Old 08-04-2010, 12:08 AM   #2
vectorit
What?
vectorit's Avatar
Re: front drive shaft
6" lift, on a stock front shaft? No, get a new one made up.
As soon as you extend the front suspension, the slip yoke will come apart.
I had mine lengthened, and I am only on a 2 inch lift.
It's not as big a deal as you may think.
Go to a good shop, tell them what lift you are doing and they will set you up.
I had mine done at:
Drive Shaft Specialist
(626) 334-2418
1117 W Foothill Blvd
Azusa, CA 91702
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
Old 08-04-2010, 12:33 AM   #3
70chevyk10dlx
ok thankss
I had mine done at:
(626) 334-2418
Azusa, CA 91702
Old 08-04-2010, 09:23 AM   #4
turp mcspray
turp mcspray's Avatar
I think you will just have to try it and see. My blazer has a 6" skyjacker lift, and the stock front shaft works just fine. I used to do lots of rockcrawling and never had a problem.
Turp Mcspray
New life for an old 2wd, farm blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=505987
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299
turp mcspray is offline   Reply With Quote
Old 08-09-2010, 02:31 AM   #5
AirSpeed
AirSpeed's Avatar
I have a 4" lift on my 72 GMC and the front drive line is barely long enough, I dont really trust it and will be getting it lengthened before it starts snowing. If I were you I would definitely have a new one made up.
AirSpeed is offline   Reply With Quote
