Old 08-04-2010, 12:53 AM   #1
Jim_PA
PCM is mounted!
It's about the best I could do! --
I need some kind of support bar to keep it from moving up and down, but other than that, its solid!
Jim_PA is offline   Reply With Quote
Old 08-04-2010, 01:05 AM   #2
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
Re: PCM is mounted!
you got the little plastic cover with it too....nice!
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 08-04-2010, 01:12 AM   #3
Jim_PA
Re: PCM is mounted!
The cover and bracket was about $25 -- they must be one of those things that get wacked a lot in collisions, so they are pretty readily available (and cheap)
Old 08-08-2010, 01:46 AM   #4
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
Re: PCM is mounted!
What year is your motor? I have a 01 6.0 LQ4. Wanting to know if my pcm would fit in that cover? Got a GM part for cover and bracket?
2 wrongs don't make a right, but 3 lefts do.
66 Chevelle Malibu 406ci, 573hp, 10.99@121mph
96 Chevy Silverado Z71
72 GMC 1500 Super Custom LS 6.0/4L65 on airride
http://www.cardomain.com/ride/707879...mc-c-k-pick-up
chevydog66 is offline   Reply With Quote
Old 08-08-2010, 09:12 AM   #5
Jim_PA
Re: PCM is mounted!
All the pcm's I've ever seen were the same shape and size
These are the numbers
15071609
15047570
Old 08-24-2010, 08:02 PM   #6
Hart_Rod
Hart_Rod's Avatar
Re: PCM is mounted!
15071609
15047570
Where did you pick up the bracket at? I called a local salvage yard and they wouldn't sell me one and all of our pick n pulls don't have them either. Thanks,
r
Hart_Rod is offline   Reply With Quote
Old 08-24-2010, 11:57 PM   #7
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
Re: PCM is mounted!
I have mine mounted also with the part #'s that Jim_PA listed. I bought them from a local GM parts seller, Midwest Auto parts.
Old 08-25-2010, 12:00 AM   #8
68GMCCustom
Re: PCM is mounted!
Jim's been away...but will pick up soon.....hopefully.
Kurt -
Old 08-25-2010, 09:46 AM   #9
Hart_Rod
Hart_Rod's Avatar
Re: PCM is mounted!
Called and ordered them today. Thanks!
Old 09-24-2010, 11:32 PM   #10
67C10BUB
67C10BUB's Avatar
Re: PCM is mounted!
15071609
15047570
Do you know if these will also fit the gen 4 5.3L?
67C10BUB is offline   Reply With Quote
