Resident of Here
73-87 swap?
What all is involved? I want to take the front clip and rear axle from a 85 C10 and put it in a 60-66(not sure which year yet). I know I will have to weld perches on the new axle if the 60-66 is trailing arm susp. I will be also putting in a Hydroboost system. Thanks.
~Bradley~ 2004 Black GTO LS2/T56 too much to list ![]() Miss having a truck ![]() |
![]() Join Date: Nov 2009
Re: 73-87 swap?
http://67-72chevytrucks.com/vboard/s...d.php?t=409676
this guy did the front clip thing. I think it's a pretty great idea. Wish I would have thought of it.
Robert 1965 Chevy C10 http://67-72chevytrucks.com/vboard/s...d.php?t=374373 1997 Chevy K2500 6.5 diesel |
Resident of Here
Re: 73-87 swap?
Thanks, anyone else?
60-66 Nut
![]() ![]() Join Date: Mar 2007
Re: 73-87 swap?
That has been done by many, many, many people. It is a very common way to convert to disc brakes....the best way IMO. Here is a thread with a bunch of info in it on the front upgrade. I did my first one almost 30 years ago.
http://67-72chevytrucks.com/vboard/s...ght=disc+brake The rear conversion is pretty straight forward, as it sounds you are aware. You'll need to weld on trailing arm mounts as well as a panhard bar mount. The '71-'87 differentials are 1.5" wider overall. Let me know if you need any brackets for your hydroboost conversion, as well as the power steering box adapter plate.
Power Steering Box Adapter Plates For Sale HERE Power Brake Booster Adapter Brackets For Sale '63-'66 HERE and '67-'72 HERE and '60-'62 HERE and "60-'62 with clutch HERE Rear Disc Brake Brackets For Sale. Impala SS calipers HERE Camaro Calipers HERE D52 Calipers HERE 6 Lug HERE Hydroboost Mounting Plates HERE Last edited by Captainfab; 08-05-2010 at 12:40 AM. |
