Old 08-04-2010, 05:37 AM   #1
psycotruckr
what makes the hood pop up in the back?
My hood is still to high in the back by the cowl and I have done all I can do. If you place your hand on it it goes down the 1/4 inch ut needs but will not stay. Are my hindges wore out or might new springs help?
psycotruckr is offline   Reply With Quote
Old 08-04-2010, 11:11 AM   #2
vin63
It's Better With Nitro
vin63's Avatar
Re: what makes the hood pop up in the back?
I'm sure you lubed the joints, but sometimes the hinge will be in a bit of a bind, or even bent.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 08-04-2010, 11:49 AM   #3
Mike Bradbury
Mike Bradbury's Avatar
I have had this same problem and have been told that the hinges are just gone. All the joints are shot and it is rubbing metal to metal. I lubed mine for days, cleaned all the rust off, did everything except take them apart and rebuild. I am planning on getting the kind that hide in the firewall.
I'd rather attempt something great and fail.. than try something ordinary and succeed. Norman Vincent Peale
Project: Barn Raising http://67-72chevytrucks.com/vboard/s...d.php?t=414961
Project: 30 Be Low https://67-72chevytrucks.com/vboard/...d.php?t=830583
Mike Bradbury is offline   Reply With Quote
Old 08-04-2010, 03:20 PM   #4
psycotruckr
I was hoping that I had missed that little magic trick to fix it but I kinda figured the the bushings were all gone. Thanks for the answers.
Old 08-04-2010, 03:54 PM   #5
leddzepp
Moderator
leddzepp's Avatar
Try this trick: Loosen the bolts that hold the hinges in the back (hood up of course) Then try to "lift" the hood so that it opens further. This will push the hinges down a little in back. Then re-tighten and close the hood. This should correct the problem. I have done this on several 67-72 trucks and it should also work on any vehicle. Good luck.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
Old 08-05-2010, 12:30 AM   #6
Captainfab
60-66 Nut
I agree. Where the hinges bolt to the inner fenders, needs to drop down in the back. You might need to slide the hood forward on the hinges also.
Old 08-05-2010, 01:15 AM   #7
skoffice
skoffice's Avatar
I have the same problem on my dad's '71 and I have tried just about every trick to get it to sit down but it just wont. I'm gonna have to find some other hinges
1964 C10 Shortened Shortbed Cammed LQ9 P&P
1967 C10 Trophy Truck BB 438 (soon to be worked on again)
skoffice is offline   Reply With Quote
Old 08-05-2010, 09:31 AM   #8
andyh1956
the hood on our 66 fit pefect UNTIL my son let it fly up & after that it sat high in the back. never could see anything xactly wrong with the hinges. it is disassembled now but i have that to fight later myself.
andy
andyh1956 is offline   Reply With Quote
Old 08-08-2010, 12:08 PM   #9
ratskin
I think maybe your seal may be holding it up. A buddy had a cheapo seal on his GMC, and it stood proud. Once he got a quality v-shaped seal it laid right down. I think Steele makes them. First try removing your seal to see if that helps.
ratskin is offline   Reply With Quote
Old 08-08-2010, 01:27 PM   #10
markeb01
Senior Enthusiast
markeb01's Avatar
Here are the factory hood alignment instructions from the 1960 Shop Manual. Also make sure the adjustable bumpers shown in figure 74 are low enough to not interfere with full closure:
Old 12-01-2014, 12:49 PM   #11
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Good info.
66 C20 Service Truck:
Old 12-01-2014, 03:02 PM   #12
Ratpin
Ratpin's Avatar
As a last resort I have elongated the mounting holes in the hinge that bolt to the firewall allowing it to be mounted 1/4" lower. Probably not the correct way to do it but it's cheap and fairly easy.
"It ain't as easy as Chip Foose makes it look"
Ratpin is offline   Reply With Quote
Old 12-01-2014, 05:12 PM   #13
verdell
verdell's Avatar
Did elongating the mounting holes work? Having the same issue with mine..
verdell is offline   Reply With Quote
Old 12-01-2014, 06:44 PM   #14
Ratpin
Ratpin's Avatar
Yes it helped. Now this was on my '59 Bel air but I see no reason it should not work on these trucks too.
Old 12-22-2014, 10:03 PM   #15
frankslagoon
Mine was just fine till I put the seal in. I haven't got it right yet
frankslagoon is offline   Reply With Quote
Old 12-24-2014, 11:56 AM   #16
cortcomp
cortcomp's Avatar
I also had the seal issue, trimmed it some and it layed right down. amazing now that little piece of rubber caused such an issue, we scratched our heads for a couple hours during assembly. You could try taping it down to test, but ours was too stiff for that.
Project "i'm just going to clean up the interior and the engine bay":
http://67-72chevytrucks.com/vboard/s...d.php?t=550931
cortcomp is offline   Reply With Quote
