08-04-2010, 08:48 AM | #1 |
Power drum brakes....
Question. The brakes are difficult even under the best of circumstances so my question is. For my 1970 Blazer 4WD 6 lug rig, I could put on a power booster from a power brake truck and leave the drums intact, right? Or do I need to find a disc brake setup? Are there 6 lug disc brakes that were stock on some 4WD rigs? Questions questions,,,,Thanks
08-04-2010, 10:52 AM | #2 |
Re: Power drum brakes....
On my 70, I swapped out the drum axel and put in a 72 disc axle with the same gears. When switching to disc be sure to change out the master cylinder and proportioning valve. Easy swap.
70 Jimmy 4x4 71 GMC 2500 Too bad stupidity isn't painful |
08-04-2010, 04:16 PM | #3 |
Don, my 71 has factory front disc six lug, good luck!
"85" Monte Carlo SS "71" K5 (SOLD) "64" Chevelle 1930 Chevy two door rat |
