Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 08-04-2010, 12:27 PM   #1
dbmx66
electric water pump question/ heater problem
how would i run my heater hose if a got a csr or meziere electric water pump?
or is there a heater that doesnt need coolant, like and electric one i can get?
dbmx66 is offline   Reply With Quote
Old 08-04-2010, 12:40 PM   #2
swb85
On a budget like Fred Sanford
swb85's Avatar
Re: electric water pump question/ heater problem
Run an outlet from the intake manifold by the thermostat to the heater core, then from the heater core into the radiator.
'85 Silverado swb: 383 stroker, 10.5:1, vortec heads, 232/238 roller cam, RPM air gap, performer 750 carb, stainless longtubes, 3" duals/super 44's, T56/4.11 383ci build / exterior refresh thread
'98 Camaro z28: 370ci twin turbo 370ci build
'01 Tahoe LT 4x4: 5.3, longtubes/ory, magnaflow duals, custom tune....wife's DD
swb85 is offline   Reply With Quote
Old 08-04-2010, 12:49 PM   #3
dbmx66
the only outlet my radiator has is the lower and upper outlet, and the barb for the catch can.
Old 08-04-2010, 05:33 PM   #4
swb85
swb85's Avatar
I know meziere will add heater/bypass fittings to their electric pumps at the factory for a fee (idk how much), but they don't come with them by default. Barring that, really your only other option is to have another fitting welded to your radiator tank. Most people that run electric water pumps don't have HVAC.
Old 08-04-2010, 06:48 PM   #5
djracer
djracer's Avatar
You could get a mojave heater that doesn't need water.
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 08-04-2010, 07:27 PM   #6
dbmx66
would you be able to send me a link or something, to get some info on it? thanks
Old 08-05-2010, 06:47 AM   #7
djracer
djracer's Avatar
the only ones I saw last night you still needed hot water for. I may be crazy..................
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 08-10-2010, 11:25 PM   #8
bigsnookmaster
bigsnookmaster's Avatar
I machined and tapped one side of my CSI and ran a 12AN fitting to run my heater hose off of, and so far have had no problems at all.
bigsnookmaster is offline   Reply With Quote
Old 08-11-2010, 03:48 PM   #9
dbmx66
thats actually a really good idea. i go to votech for cnc/ manual machining, i could prolly do that.
do you know if it voids a warranty or something, i have a meziere coming in the mail
Old 08-11-2010, 06:34 PM   #10
bigsnookmaster
It might void the warranty. If you could do it on the vertical side, it would be easier, but I did mine for aesthetic reasons, so it would run parralel with the top hose which is just out of the picture.
Old 08-11-2010, 10:28 PM   #11
dbmx66
oh okay. i was also thinking of cutting a hole and welding in one of the those weld an fitting, the have one from the radiator and one from the intake manifold, would that work?
