Well a car rad work in my 59 truck?
I have a chance to buy a NOS rad that is made for a 55 Chevy car. Are the rads in those days the same between cars and trucks.
![]() Join Date: Mar 2009
Re: Well a car rad work in my 59 truck?
The brackets are different between car and truck. You could possibly adapt it. I've heard that the truck rad is taller too.
I've been looking for a rad for my 57 and have come across a good deal. They are aluminum with a formed top tank that looks just like the original, 2 rows of 1" tubes, and a proper trans cooler in the bottom tank. The best part is the top tank is polished for no extra charge. Here's a pic of their 55-57 car rad, the truck one will have the proper brackets for truck. ![]() The price is excellent and I've talked to them regarding a group buy for members of the forum for an even better deal. I'll post details in a seperate thread as soon as I found out if it's ok to do so. Sorry for the hijack, thought I should let you know. Bob
1957 Chevy black 1420 LBSS 1955 Chevy green 1300 SBSS 1956 GMC red SBSS Nov 2017 ToTM https://www.facebook.com/groups/Cana...geChevyTrucks/ Last edited by bobinbc; 08-04-2010 at 04:52 PM. |
I'd be really interested in one of those for my 58. Can I get more info?
1958 Fleetside shortbox 1965 Malibu SS 1970 Camaro RS 1972 Malibu wagon |
Where are they made?
No, they are quite a bit different. You can make the car radiator work, but you will never convince anyone it is stock. Speaking for myself, I would get it if the price is right, because my time is always cheaper than my money.
Ray |
Ray what the difference is between them?
The brackets, like bobinbc said. But it will work, if you don't mind it not looking stock. On the other hand, if they are close in price, I would get the right one for the truck. How much $ difference are we talking about here?
Ray |
I asked this question along with a couple others, this is the reply I got.
"Bob, The FPI is 15, the fin height is 11/32" and they are made here in our shop. Mike - engineered-products" (Chicago, Il ) HiRMKin Here are some pics I pulled off the net to show the difference between car and truck. This is not the rad I'm going with, the one I'm going to use has stock looking tanks like in my earlier post above. Truck rad brackets Car rad brackets The car rad:Core Dimensions: 17 1/4" high x 21 1/2" wide Overall Dimensions: 23" high x 23 1/2" wide (incl brackets) truck rad :Core Dimensions: 20" high x 21 1/2" wide Overall Dimensions: 25" high x 26 1/2" wide (incl brackets) The pics are of aftermarket aluminum rads but you can see generally the difference between the brackets. The other thing is whether your engine is stock or not. If stock and the rad is a smokin' deal then I would adapt the car rad even though it's 2 inches shorter, unless I was doing a resto. Just my .02
1957 Chevy black 1420 LBSS 1955 Chevy green 1300 SBSS 1956 GMC red SBSS Nov 2017 ToTM https://www.facebook.com/groups/Cana...geChevyTrucks/ Last edited by bobinbc; 08-05-2010 at 12:51 PM. |
Car has 23% less cooling area too. I went the opposite way, found a big truck radiator that is a little wider and 1" thicker than 1/2-1 ton ones, mounts to stock brackets.
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project |
Bobinbc, your info is what I found as well, just had to confirm I was right. I'm going to pass on the rad as I will be running a sbc 406. I'm going to need all the cooling I can get.
Great info guys. Thanks |
| Bookmarks |
