Which brand lift kit?
I am looking for an all suspension lift kit for my 71 gmc. Wanting 8"-10". I can't seem to find any place that sells them.
07 Chevy classic LBZ Duramax (a few mods) '67 Chevy 1/2 ton 2wd (in pieces) '69 Chevy 1/2 ton 2wd (on hold) '71 GMC 3/4 ton 4x4 ‘71 GMC 1/2 ton 2wd suburban |
Re: Which brand lift kit?
Here is Skyjacker's part number for their 8" lift - C280AKS.
http://www.skyjacker.com/products/pr...tail/?id=41761 |
If I go with an 8" will I have to modify my drive lines?
SWB 4x4 Collector
![]() Join Date: Jun 2001
yes, you will have to have your driveshafts lenghtened. 4" pushes it, and I believe at 6" and above they will have to be lengthened. Also, I believe Skyjacker has the only 8" kit for our style out there, although Superlift may, but don't quote me on that. Trevor
TREVOR ![]() ![]() ![]() ![]() ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=624819 ![]() ![]() :2004 Jeep Wrangler Rubicon (daily driver) WTB: 1968-70 Cruise Control Lever |
One of the First
![]() Join Date: Jan 2000
Whew! 8-10 inches! Tell us it's not a daily driver! Just kidding! You will have to play with your angles on your axles and you might consider using latter bars to stabilize. Dual shocks also... Its a project with alot of mods. Hey, keep us posted...
DAVID PASSMORE ST AUGUSTINE ,FL ZIP 32084 '71 SWB K/10 CUSTOM DELUXE (Chili) '72 BLAZER K/5 Muscle Truck (Mule) '72 LWB K/20 CHEYENNE (Blackie) |
I'm going with Skyjacker on my '72 K20. In researching I had found everyone stating they seem to ride the best. I ordered mine from 4wheelparts.com they seemed to have the best prices the also run specials with free shipping from time to time. The shipping charges are normally very high due to springs being very heavy.
I am pretty set on an 8" now and no bigger. My buddy has a 79GMC with a 12" lift with 39" tires. He bought it that way and has thought about getting a smaller lift. I would go with a 6" if it saved me money, but the prices seem to be about the same.
Gearhead
I would think the driveline angles would be corrected in the spring packs, they usually include shims built right in. I sold truck accessories for 6 years and never saw a lift that big that didnt have the shims right on the packs. You will definetly need the shafts extended, I would look into the 8" and make sure that you dont need a CV stlye driveshaft or have to "reclock" the transfer case. If it is a S/B, I would be concerned of the rear driveshaft angle at that height. Just my .02
2002 Saturn SL2, My D/D 2019 Ford Fusion SE, Ecoboost - Wife's D/D 1993 Camaro Z28, A4, CAI, Cat-Back Exhaust Project C10 (my 72' C10 w/96' LT1, 700R4, bagged F&R, 18's (for now), Short/Fleet) -- SOLD! Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=313644 |
awesome!!!
i am thinking of the same exact thing for mine |
#10 | |
I'm getting close to the point where i want to go ahead and replace the rear blocks with a spring kit so was looking at this kit: http://www.4-wheel-drive-lift-kits.c...r-springs.html Do you think from your experiance that this kit will have a better ride than the rancho kit i have? Thanks! |
Gearhead
I have heard that the Skyjacker kits ride better than most of the other kits available. The thing to remember is that a spring rides progessively worse the more arch it has in it, BUT the lifted springs tend to be softer than "factory" springs. They usually have more leaves than stock, but are usually thinner (and sometimes tapered) to help with "flex", which is better for ride quality. So long story short, I would bet the full replacement springs would ride better for you at a 4" height, any bigger than that and the arch is gonna start killing ride quality again. I also believe that a quality (read Bilstein) shock goes a long way as well. Just my .02
#12 | |
