Old 08-05-2010, 11:13 AM   #1
cariboo4x4
Early 60's gmc 930 idf help needed...
I recently got an old early 60's gmc 930 flatdeck. The id on the door frame says:
Model C93603
Serial 0C93603608195B
Engine C494584
The truck has straight 6 and 4 speed standard.
The bit of info I found here the serial breaks down as:
0 C 93603 6 08195 B
0 1960
C can't remember
93603 Series\model
6 six cyliner
08195 production number
B GVW 6,000 to 10,000
I still not sure of the year and the engine id. 292??
The more I know the better chance I can get the previous registered owners name from ICBC up here in BC, Canada....
cariboo4x4 is offline   Reply With Quote
Old 08-05-2010, 12:12 PM   #2
raycow
Re: Early 60's gmc 930 idf help needed...
I believe Canadian GMCs had Chevy engines. Surely someone will correct me on this if I am wrong. If the truck is a 1960, this means the engine is most likely a 235 (a US GMC would have a V-6). GVW 6000-10000 means the truck is a 3/4 or 1 ton. 8 lug wheels would confirm this. Could you possibly post a pic of the truck and the engine?
Ray
raycow is offline   Reply With Quote
Old 08-05-2010, 02:08 PM   #3
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
0 is 1960
c regular cab
9 gmc
36 one ton
i'll get you some info from the canadian parts book tonight.
Old 08-05-2010, 06:25 PM   #4
aerotruk63
aerotruk63's Avatar
Old 08-05-2010, 06:31 PM   #5
aerotruk63
aerotruk63's Avatar
Ray
Quite right Ray, Canadian GMC trucks came with Chevrolet drive trains.
Old 08-09-2010, 12:21 PM   #6
cariboo4x4
Thanks for all the info. Heres some pics. I'd like to fix up the outside of the body so as not a heat score. I have a 1983 1 ton chev cab I could put on this frame but the 1960 cab is so cool! Paint it another color though
Old 08-11-2010, 07:35 AM   #7
63sbssbbw
UCA63
63sbssbbw's Avatar
Welcome to the site Caruboo from a former BC'er
Lots of good stuff here
great lookin' truck you've got,looks like rust in all the usual places,no worries,replacement panels are available for darn near every part of your cab,with exception of A and B pillar and roof.They do make the filler piece between the roof gutter and windshield,but any I've seen with this problem have rust on the interior side too.
If your windshield isn't cracked,take good care of it,good ones(pilkington or imperial)are hard to find and expensive when you do find one (I,ve heard the repros dont fit very good)and make sure your new rubber is a GM part(about $40) not a repop.
I think it would go great on a later 4x4 chassis(there's info here on that too)
Don't forget to check out the Canada section too.
Have fun
T
member#7816
"63 sb ss bbw 350\350 12 bolt rear Pwr Fr Disc PS tilt
'61 GMC in progress
'63 GMC to use for parts
'90 Chevy Ext cab sbfs 5.7l (current d d)
63sbssbbw is offline   Reply With Quote
