08-05-2010, 12:38 PM | #1 |
66 8 lug
im working on a 66 gmc with 8lugs for a friend he wants to do a disk brake conversion retaining the 8 lug set up could any body help me with what parts (factory hopefully) i could use from what years and what power brake booster would fit thank you
08-05-2010, 04:00 PM | #2 |
Re: 66 8 lug
Everybody unbolts the later year front crossmembers to switch over to 5 or 6 lug but you can do the same from a 3/4 ton of those years just to obtain the disk brakes. I personally bought and installed 2.5" drop spindles and disk brake swap from Brothers Trucks and everything bolted up fantastically.
65 Chevy C-20 Chopped 3", Doors Suicided, completely shaved, 650 hp BBC |
08-05-2010, 04:04 PM | #3 |
60-66 Nut
Re: 66 8 lug
You can convert over to discs with a front suspension from a '71-'87 pickup and Suburbans and Crewcabs thru '91. You can use the whole braking system as well as the power steering. The factory brake booster will work if you don't mind drilling a couple holes to bolt it up. I sell booster brackets that bolt up to the firewall using existing holes, as well as the power steering box adapter plates. Links are in my sig.......
08-06-2010, 10:33 AM | #4 |
Re: 66 8 lug
http://www.chevytalk.org/fusionbb/sh...hp?tid/223597/ Check out this post and I am sure it should give you enough info. I helpped out on this swap.
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
08-08-2010, 12:38 PM | #5 |
Re: 66 8 lug
now my friend is thinking a bout retaining the drum brakes but wants to add a dual master and power booster does any one know what would fit the truck and would i need a portion valve with the four drum set up thank you for all your answers
08-09-2010, 12:29 AM | #6 |
60-66 Nut
Re: 66 8 lug
For the dual reservior master cylinder, you'll need one for a '67-'70 truck with power brakes. For the booster, one of my booster brackets will work with the recommended booster (see the link in my sig). As for the proportioning valve, one isn't needed for 2 wheel drum brakes. The '67-'70 trucks used what amounts to basically a distribution block directly below the master cylinder.
08-14-2010, 11:49 AM | #7 |
Re: 66 8 lug
how much is the bracket and do you have the booster if yes how much this is for the drum/drum set up
08-14-2010, 11:23 PM | #8 |
60-66 Nut
Re: 66 8 lug
At this time I don't sell complete kits. There's not much sense in paying shipping for the parts that you can buy locally. The brackets are still $65.00 shipped as listed in the for sale thread. If you don't mind paying the shipping and would rather buy a package setup, let me know and I'll see what I can do.
Power Steering Box Adapter Plates For Sale HERE Power Brake Booster Adapter Brackets For Sale '63-'66 HERE and '67-'72 HERE and '60-'62 HERE and "60-'62 with clutch HERE Rear Disc Brake Brackets For Sale. Impala SS calipers HERE Camaro Calipers HERE D52 Calipers HERE 6 Lug HERE Hydroboost Mounting Plates HERE Last edited by Captainfab; 08-14-2010 at 11:24 PM. |
