08-05-2010, 04:31 PM | #1 |
Super Newb
Coil Spring compatiblity with different years?
I'm replacing a bunch of suspension parts and I found some used springs locally that I am hoping will fit. I've looked all over this site and can't find the info I need. Hopefully someone can help me out.
The front coil springs I found are from a 73-87 truck, and I was wondering if they would also fit my 66 truck. I am pretty sure they will fit 67-72, but I'm not sure if they will fit my 66. Thanks for any help you can give. |
08-05-2010, 05:06 PM | #2 |
Re: Coil Spring compatiblity with different years?
They're not exactly the same but will interchange.
08-05-2010, 05:15 PM | #3 |
Super Newb
I just found out that the springs are actually from a 67-72, not 73-87. Hopefully this means that there is a better chance of them fitting.
08-05-2010, 05:27 PM | #4 |
The crossmembers interchange & the springs will as well.
08-10-2010, 11:16 AM | #5 |
Super Newb
I think I'm just gonna carefully cut 1 coil of the stock front springs for now. The 3" drop springs are too much drop with out doing a ton of other suspension work.
