Old 08-05-2010, 06:35 PM   #1
cb1965
cb1965's Avatar
New engine help
alright guys heres my issue.
i have a 65 chevy with a beat up 350. its basicly a parts engine witch i figured out when i took it appart to clean it. the block is from a 70 car, heads are 76-85 truck, i think. intake is a 68 truck. 2 barrel rochester year vehicle ??? who knows. i tried to make it work but now the valve stems are bad and rocker nuts keep loosening. block is bored .40. im tired of messin with it. srry for the rrrrrrrant
point is i want to drive the heck out of it but right when it seems to be good something new happens.
what is a good crate engine that i can drop in and go for a good price. i want it to be a DD and not looking for anything fancy. i have the original powerglide still attached. thanks in advance
this site rocks
cb1965 is offline   Reply With Quote
Old 08-05-2010, 07:11 PM   #2
blackedoutharley
Re: New engine help
The 290hp GM 350 is a fantastic engine and would deliver plenty of power without breaking the bank.
Have you checked the cylinder walls and measured them?
If they are good why not just re-ring and bearing the short block and install a new set of aftermarket iron heads?
blackedoutharley is offline   Reply With Quote
Old 08-05-2010, 09:32 PM   #3
cb1965
cb1965's Avatar
Re: New engine help
thanks Blackedout,
do you have a link. im really sick of dealing with that engine so i really dont want to bother anymore. plus the crank is stripped where the harmonic balancer bolts on to. i got maybe 2 threads in
Old 08-05-2010, 10:17 PM   #4
WellBilt Kustoms
Re: New engine help
I have that engine swapped into my 1950 ford (I know...it has a camaro front clip on it). Its a good engine for the money, and surprisingly has a pretty good amount of power. I have sanderson headers on it, flowmaster exhaust, comp cams camshaft, edelbrock intake manifold, holley carb, HEI dist. with taylor 8mm wires, and it runs and sounds great!
I got mine from summit.
WellBilt Kustoms is offline   Reply With Quote
Old 08-05-2010, 10:24 PM   #5
cb1965
cb1965's Avatar
Re: New engine help
is it a long block or a complete engine carb to pan?
Old 08-06-2010, 03:42 AM   #6
blackedoutharley
Re: New engine help
http://www.summitracing.com/parts/NAL-12499529/
Old 08-06-2010, 05:42 AM   #7
fryer1979
Redneck Hillbilly
fryer1979's Avatar
Re: New engine help
^+1 For an inexpensive crate engine (everything is new), this one is hard to beat. Comes with a warranty, has enought power to be fun on the street, and is still mild enough that fuel mileage and drive-ablility is more than reasonable. I know quite a few guys who have this engine for exactly what you are looking for, and love it.
fryer1979 is offline   Reply With Quote
Old 08-06-2010, 10:10 AM   #8
Chevy Fleetside
Chevy Fleetside's Avatar
Re: New engine help
call up the dealer near you and tell them you want a crate engine and how much they can get you one for. You live in San Jose so there are many around. I got a crate engine for my 79 in Pittsburg @ Winter Chevrolet .
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 08-06-2010, 10:15 AM   #9
Chevy Fleetside
Re: New engine help
http://www.fhdaileycars.com/PartsOrderForm Try here. They might be expensive though. You can also look in the phone book and make some calls.
Old 08-06-2010, 01:08 PM   #10
creep
Registered Loser
creep's Avatar
Re: New engine help
You may want to check out Blueprint Engines. They have lots of different packages and are fairly inexpensive. I got thier 405 hp 383 longblock with intake manifold for on sale for $2965 (normally around $3200) before taxes. They use remanufactured blocks but everything else is brand new and they come with a 30 month warranty. Summit Racing and Jeg's both carry them.
'63 GMC lwb, 383, th350, lays frame, genuine patina.
The Build Thread - http://67-72chevytrucks.com/vboard/s...d.php?t=374267
'88 Astro cargo bagged, shaved, phantom grille. *SOLD*
'50 Chevy 2 door sedan awaiting attention.
2014 Silverado Ext cab, 5.3, daily driver.
creep is offline   Reply With Quote
Old 08-06-2010, 03:45 PM   #11
Big Fenders
Re: New engine help
For a new 350 I'd check out Jeg's. They beat Summit prices too. As mentioned the 290 HP is quite an engine but you mentioned saving a few bucks. The 260 HP engine fron Jeg's sounds like the way to go..check prices and compare...btw these are new engines not rebuilt with a nice warranty.
Bob
Big Fenders is offline   Reply With Quote
Old 08-06-2010, 04:44 PM   #12
cb1965
cb1965's Avatar
Re: New engine help
Thanks for all the input.
what intake and carb would work well with either the 260 hp or 290 hp engine? this way i can compare and see what my pockets can handle.
i dont have a specific budget but dont want to go crazy. if it feels right i ll go for it. thanks
Old 08-06-2010, 05:04 PM   #13
blackedoutharley
Re: New engine help
Stay away from single plane manifolds!
The Edelbrock Performer RPM and a 600 Holley (#1850) work perfect. Also, if you don't already have one I highly recommend going to HEI ignition.
Old 08-06-2010, 09:44 PM   #14
cb1965
cb1965's Avatar
Re: New engine help
would this be a good set up? im not sure what works with what.
http://www.summitracing.com/parts/NAL-10067353/
with
http://www.summitracing.com/parts/CMB-03-0077/
Old 08-07-2010, 01:34 AM   #15
Captainfab
60-66 Nut
Re: New engine help
That top end kit would work, but for the slight difference in money I would go with at least the 260hp engine.....it's only $200 more for an extra 65hp.
with
Old 08-07-2010, 12:48 PM   #16
cb1965
cb1965's Avatar
Re: New engine help
is there a link to the 260hp. i only found the 195+hp and 290 on the summit page. i think i wanna go with the 260
this would be my first engine purchase. exiting and scary.
Old 08-07-2010, 02:35 PM   #17
Big Fenders
Re: New engine help
I'll try again...check Jeg's for best price
Bob
Old 08-07-2010, 02:42 PM   #18
cb1965
cb1965's Avatar
Re: New engine help
big fenders,
is this the one?
http://www.jegs.com/i/GM+Performance...67353/10002/-1
Old 08-07-2010, 03:25 PM   #19
markeb01
Senior Enthusiast
markeb01's Avatar
Re: New engine help
I found the receipt for my engine, that's the one I have 10067353. I'm running an Edelbrock Performer RPM manifold (because I got it for free) along with a 1405 600 CFM Edelbrock carb, and stock HEI. The only engine modification is a Pete Jackson gear drive. It has somewhere around 150k on it now and still runs great. Whenever the budget allows I'll replace it with the same thing. I believe the only differences on the 290 hp version are a nodular iron crank and a different cam. Unless you're going to build it up I'm not sure that's worth another $500.
Old 08-08-2010, 01:04 AM   #20
Captainfab
60-66 Nut
Re: New engine help
Yes that is the 260hp engine.....and yes Jegs does have the better price....the same price as Summit wanted for the 195hp engine. I see Jegs has some packages listed down towards the bottom of that page.
Old 08-08-2010, 01:41 AM   #21
bama63
bama63's Avatar
Re: New engine help
you cant beat the 3 years or 100,000 miles warranty, i have installed a half dozen of the gm crate engines in various vehicles without any problems and the confidence of a nationwide warranty covered at any dealership
bama63 is offline   Reply With Quote
Old 08-08-2010, 05:27 AM   #22
blackedoutharley
Re: New engine help
Don't forget to factor in the cost of freight as well.
The Edelbrock EPS manifold is also a good choice but I cant say anything about their carbs; no experience with them.
Old 08-10-2010, 09:51 AM   #23
Big Fenders
Re: New engine help
That is the one.Iv'e ordered two for different projects and completely satisfied.
BOB
Old 08-10-2010, 04:42 PM   #24
cb1965
cb1965's Avatar
Re: New engine help
thanks for all your help guys. i placed the order sunday night from JEGS. hopefully i get it within a week.
i also ordered some parts from summit. should arrive today. i always get my orders from summit with in 2 days. very cool
also can i use water pump, fuel pump, alternator, and ballancer from old engine?? all are new
Old 08-11-2010, 12:36 AM   #25
Captainfab
60-66 Nut
Re: New engine help
You can use all that on your new engine.
