Really Annoyed
With my truck lately.
Its not even that hot in Southern California lately, but seems like my truck wont start at all when its somewhat hot outside. For instance today, went to RCC (community college) looking at classes and when I'm about to leave my truck wont start. I turn the key but nothing happens. No clicks or anything just a the brake light comes on in the truck. Anybody know how I can fix this problem?
~~'71 GMC shortbed. Recently, 2007 Mazda 3 hatchback. |
Between Trucks...
Re: Really Annoyed
Are you running headers?
Beat it to fit, Paint it to match... ![]() |
Re: Really Annoyed
Nope. Completely stock small block 350. Running stock manifold from when I got it.
Re: Really Annoyed
take off battery cables and clean up all 4ends and where they attach to then try it
just looking at them unless you have xray vision doesnt help
#5 | |
Re: Really Annoyed
What should I clean them with?
20' Daredevil (Ret)
![]() Join Date: May 2003
Re: Really Annoyed
Baking soda & water works, then rinse with water. Small wire brush (or sandpaper) will help clean off any remaining crud or corrosion, and it wouldn't hurt to smear on a little dielectric grease to help protect against future corrosion.
Re: Really Annoyed
You might want to take a look at your starter. I had a stock GM starter on my Sons 64 and it was doing exactly the same thing. I would hit my starter with a hammer and then it would start. Just a thought.
JRBECK64 |
dazed and confused
Re: Really Annoyed
is it an automatic on the column? mine done that and the neutral saftey switch was givin me a fit. you could wiggle the shifter and push up on it and it would start.
members met: redbaron69, billsbowtie,nc67 |
Re: Really Annoyed
Automatic. And the above post. My dad was telling me something about the starter. Maybe it just gets to hot? Because today when it didn't start I just opened my hood to let it cool off and it started but i had to give it a **** load of gas. Didn't sound good at all.
Junior Member
Re: Really Annoyed
I had the same problems with my '67 with a 250 L-6 and I finally got it fixed after I replaced the positive and negative cables and replaced the solenoid.
'67 Chevy C-20 short stepper - build complete, 454/SM-465. '75 C-30 Single Cab DRW-350 small block/NP-435. '77 GMC-6500 Dump Truck, 427 Tall Deck. '92 GMC K-3500 Duallie, 454/4L80E. |
Re: Really Annoyed
Where is the solenoid located?
Re: Really Annoyed
Solenoid is bolted to the outside of the starter.
72 Fleet (died) 78 Step (sold) 55 Step named Fred (sold) 00 F150 68 Step (named El Scorcho by PO) Build thread for the new El Scorcho http://67-72chevytrucks.com/vboard/s...d.php?t=392932 |
#13 |
Re: Really Annoyed
Thank you. I was talking to my dad and he said it might be the ignition?
#14 |
Between Trucks...
Re: Really Annoyed
If your timing is too advanced it can be hard to start when it's hot. My guess is the solenoid like has been mentioned though.
#15 |
20' Daredevil (Ret)
Re: Really Annoyed
IF timing is the problem, the dist. weights could be stuck in the advanced position...
#16 |
Re: Really Annoyed
hi everybody, my first post
#17 |
NEWBIE!!
Re: Really Annoyed
When you find out the problem to this tell me LOL. Mine has had the same problem, I rewired all the starter wires, Went through 3 different starters, re-did this and that. The only thing I haven't tinkered with is the actual ignition switch. I do know I had to shim mine, It hasn't done its thing since I shimmed it, but Its really hard to diagnose when it doesn't do it all time. Good luck to you
Water is for the weak I don't like cocaine.. I just like the smell of it "Well there might be a dime up a goats ass too, but I ain't looken" - Grandpa VolksRods |
#18 |
Re: Really Annoyed
The other day i went to start my truck i turned it over for a sec then stopped an then tried again an nothing it didnt even click so i gave up an went to where i was going in my car then came back wiggled the wires an played around a little bit then it worked fine, i was wondering if it was the solenoid too but it hasnt done it sense.
#19 |
Re: Really Annoyed
i have had this issue with my ign switch loose wire. also my sound stupid but check all you ground wires you will be supprised how many times it is something simple like that
1972 ![]() my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=418015 |
#20 |
Re: Really Annoyed
That bump it with a hammer thing works if your starter has a flat spot. This, cleaning the battery post, and checking the wiring are all free, and easy to do.
#21 |
Re: Really Annoyed
This was happening to me so I replaced the starter, haven't had it happen since and it was about a year ago. I'm running headers so it cooked the first starter. I bought a lifetime warrantied starter this time and hopefully I never have to use it.
Mine would start just fine after I let her cool down for a bit. I would go somewhere and have to sit in there parking lot for 30 minutes to an hour waiting for the starter to cool down enough that it would want to crank.
'70 K10-- 4" lift on 35"s-- For Sale http://www.ksl.com/index.php?sid=733...iew&ad=4578305 Last edited by Nova70; 08-06-2010 at 03:06 AM. |
#22 | |
Junior Member
Re: Really Annoyed
#23 |
Gearhead
Re: Really Annoyed
I had the same type of issues as described and I finally put a heat shield on the starter and an external soleniod (think F**d type) and havent had a problem since. I used to carry a bottle of water and just dump it on the starter when it was too hot, but I dont recommend it around hot headers!
2002 Saturn SL2, My D/D 2019 Ford Fusion SE, Ecoboost - Wife's D/D 1993 Camaro Z28, A4, CAI, Cat-Back Exhaust Project C10 (my 72' C10 w/96' LT1, 700R4, bagged F&R, 18's (for now), Short/Fleet) -- SOLD! Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=313644 |
#24 |
Re: Really Annoyed
I hate to admit how long I put up with the same problem. When mine was hot after stopping for an errand or two on the way home from work it started every time with an old ratchet shorted across the solonoid terminals. Works great and easy to get to with rams horn manifolds. I even did it a few times while the cop who stopped me was climbing back on his scoot. I got good at making sure the key was on before I got out and opened the hood.
In the course of a year or two I changed battery twice and both cables, relays and starter twice. The final fix was a smaller high torque starter to keep distance between the exhaust. I think it was from a 95 Camaro. Put it on 4 months ago and never a problem since even with 105 degrees most afternoons. |
#25 |
Re: Really Annoyed
Does your truck still have all the ground straps attached? I would buy a black battery cable about 16 inches long and bolt one end to the head or motor mount and the other to the frame.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
