Old 08-05-2010, 08:40 PM   #1
Sonicman
Sonicman's Avatar
Piston question
I have an 69 c10 with a 250 inline 6 and had it about 2 months. I am rebuilding the engine. Well my buddy and I were putting the rings on the pistons and he dropped one and cracked the side. Now where can I find one. We took it to a local machine shop and they said it didn't look like the original piston and that it is bored .060 over. This is my first rebuild so I'm clueless. I've looked at pics on ebay and seen pistons to a chevy 350 that look like my pistons and are bored .060 over.
Can someone please shed some light for this newbie.
Sonicman is offline   Reply With Quote
Old 08-05-2010, 08:59 PM   #2
pritch
pritch's Avatar
Re: Piston question
Someone will correct me if I'm wrong-but I think they are the same as a 307 piston. But either way, they should be pretty common.
'68 Panel
Project Boogie Chillin'
'68 C-10
Ol' Green
pritch is offline   Reply With Quote
Old 08-05-2010, 09:24 PM   #3
LandonL
LandonL's Avatar
Re: Piston question
Alright, first of all you know for SURE it's bored .060 over? If so the standard bore for my inline 250 was 3.875 so when you add the .060 over it brings it to a bore size of 3.935
Here are all the pistons with a bore size of 3.935 (.060 over) http://www.summitracing.com/search/P...eyword=Pistons
The ones that don't have pictures may have valve reliefs like yours have now.
Also, did your cylinder walls have a ridge you could catch your fingernail on?
---| 1967 GMC Stepside |--
250 L6 .030 over
---| 1985 Porsche 944/1 |---
Build Thread: '67 GMC
http://67-72chevytrucks.com/vboard/s...d.php?t=378640
LandonL is offline   Reply With Quote
Old 08-05-2010, 09:52 PM   #4
Sonicman
Sonicman's Avatar
Re: Piston question
I don't believe there is a ridge. The cylinder walls are completely smooth.
The one shop I did take my piston to told me that it is bored .060 over. I've only had the truck for just over a 2 months. I don't know the history of the the truck. What are the valve reliefs for? Does their placement matter?
Old 08-05-2010, 09:54 PM   #5
LandonL
LandonL's Avatar
Re: Piston question
Well, you need to know the bore size before you buy your piston, if you find theres a ridge you can catch your fingernail on you might wanna have it bored again, not sure if you can go much more though.
250 L6 .030 over
Old 08-05-2010, 10:51 PM   #6
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: Piston question
Whats stamped in the red circle? is it 060? if it is then its a 60 over piston. 6 cylinders usually have flat tops or dished but not valve reliefs.
I have read that you can take a 250 six cyl. and put 283 rods and flat top pistons, so maybe what you have are 283 pistons and rods. There should be a casting number on the rod and piston
dwcsr is offline   Reply With Quote
Old 08-05-2010, 11:57 PM   #7
Sonicman
Sonicman's Avatar
Re: Piston question
Yes the pistons are stamped 60. I see no markings on the rods.
Old 08-06-2010, 02:13 AM   #8
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: Piston question
I see that 307 pistons are 1.655 Compression height and the same bore as the 250 piston having a 1.640 Compression height, pin diameter is the same. You may well have 60 over 307 pistons in there. The book say the 307 has valve reliefs and the 250 is dished.
Old 08-06-2010, 09:17 AM   #9
raycow
Re: Piston question
I agree completely with the previous posts. Those are definitely V-8 pistons, because an inline wouldn't have valve reliefs on both sides. Valve reliefs are needed on some engines to prevent piston to valve contact at the top of the exhaust stroke. Replace it with another of the same type, just in case there is a weight difference between the 6 cylinder and V-8 pistons. Install the pistons with the small notch facing the front of the engine.
Ray
raycow is offline   Reply With Quote
Old 08-06-2010, 09:53 AM   #10
Sonicman
Sonicman's Avatar
Re: Piston question
Thank yall for sharing your knowledge. This is my first rebuild and I am really enjoying it. Keep it coming!!!!
Old 08-06-2010, 10:12 AM   #11
cdowns
cdowns's Avatar
Re: Piston question
i'd get in touch with EGGE and see about sending them the bad piston so they could either matchup with an over the counter piece or if not they can reprroduce it
Old 08-06-2010, 05:30 PM   #12
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: Piston question
As cheap as these pistons are I would just replace them all with either the 6 cylinder or the 307's and be done with it, providing a bore job is not needed. If not lip is seen the clean it up with a finishing hone and measure the bores.
Old 08-06-2010, 06:17 PM   #13
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Re: Piston question
I agree the one you posted looks like a 307 piston.If you can replace them with 307 ones or the 250 pistons for use with propane.The compression ratio will be higher 9:1 vs 7.5-8:1 which will give you a bit more power even in a stock rebuild.You may need to replace all of them to get a match.And they do need to match.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 08-06-2010, 07:49 PM   #14
Davetopay
Re: Piston question
Hmmm..if he does in fact have the taller pistons, that could be a cool hotrodding trick to bump compression.
Davetopay is offline   Reply With Quote
Old 08-06-2010, 11:13 PM   #15
pritch
pritch's Avatar
Re: Piston question
Ah-I remember now. It's the 230 that is a direct exchange for 283 pistons.
Compare part numbers here for example:
http://www.flatlanderracing.com/trwpistonschevy.html
I keep forgetting that some PO had stuck a poorly rebuilt 230 in my Panel. I had to replace a piston 2 seperate times in the several years I drove it around before the tear-down.
'68 Panel
'68 C-10
Ol' Green
Old 08-07-2010, 12:03 AM   #16
Sonicman
Sonicman's Avatar
Re: Piston question
Finally got my pistons, and who would of thunk it.....I got'em from O'Reily's. They are .060 for a 250 L6. I got all 6. There are no valve reliefs in them just a "D" shaped compression. Can't wait to drive her again.
Will get it all buttoned up in the morning. Gona take a break for a bit and then hope to get Clifford Performance exhaust headers and intake. Once again, thank yall for the help
