![]() Join Date: Jul 2010
3 on the tree problem
My column shifter is getting more and more difficult to work. What is my best option? I know it is the shift mechanism on the steering column under the hood. I would like to keep it for the originality. What should I do?
Re: 3 on the tree problem
I'm having the same problem, hope someone can help. JJibs
Active Member
![]() Join Date: Jul 2007
If all of the rubber grommets are in place and not worn off then you may have to relube the shift lever shaft inside the column. The original grease has caked up and dried up to the point where it is hard to shift.
In some cases you can pour wd40 or some other libricant into the shaft and loosen it up. In my case, I had to take it out and take it apart and relube it. |
I have greased the visible portion. Put a heavy coat on it. But still difficult. How difficult is it to take apart?
#5 | |
This is pretty sound advice I read elsewhere.
Has more rust than truck...
This may help,
FAQ on shifter adjustment- http://67-72chevytrucks.com/vboard/s...d.php?t=215307 |
Grandpa in the rustmobile...
New bushings would help too, im not all that sure WHERE to get em, if anyone has a link post up..(correct bushings, all 4)
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
Trans arms- http://www.classicparts.com/1960-76-...ctinfo/91-063/
Column shift arms- http://www.classicparts.com/1947-76-...ctinfo/91-062/ |
hey ive seen those before, im scared to order from them,last time i did it took 6 months for my mirrors to get in, 'oh there just backordered they'll be here next week'
#10 | |
