08-05-2010, 11:33 PM | #1 |
New to lowering truck.
I have decided to do 5/7 drop on my 85. Could someone tell me what is needed to accomplish this.
I assume the front would be 3" drop spindal w/2" drop spring. The rear is what I have some concern about. What is the best way to get the 7" drop in the rear. What would be the best shocks to buy. I would like to get some very good shocks all the way around. I tow a 18' boat once and a while and would like to be able to raise the rear alittle to be able to tow my boat. I'm going to use 20" wheels on it,so I'm not sure if the rear would scrub while towing my boat. Could you use air bags just for the rear to air up and down? If anyone knows where I could go to read up on doing this would be great. Thanks for the help. |
08-06-2010, 09:50 AM | #2 |
67-72 parts collector,…
Re: New to lowering truck.
Look at member bigarmzz threads.
He's did the exact drop you are talking about. Airlift Company make several styles of load leveling air bag set-ups, that will help you tow your boat. http://shop.airliftcompany.com/dyn_search_vehicle?k=0 Check out these two threads: http://67-72chevytrucks.com/vboard/s...d.php?t=396818 http://67-72chevytrucks.com/vboard/s...d.php?t=401131
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 08-06-2010 at 10:29 AM. |
08-06-2010, 01:14 PM | #3 |
i was just going to make the same thread, thanks!
1979 c30 3+3 dually 1946 GMC |
08-06-2010, 01:18 PM | #4 |
oh and, wheres the best place to order a 2" shackle and drop springs separate instead of a kit since i already have a flip kit and spindles....can i just cut off and junk my old shackles? (sorry to hijack but i figure itll help and no need to start a new thread)
08-06-2010, 02:05 PM | #5 | |
http://67-72chevytrucks.com/vboard/s...d.php?t=394604
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 08-06-2010 at 02:08 PM. |
08-08-2010, 09:17 PM | #6 |
Any problems with pinion angle?
