incremental squeaking
Hi guys,
probably a stupid question here... i am getting a squeak from one of the front wheels, but only when i turn the wheels to the left. If I apply the breaks it goes away, but i don't think it is a wear indicator because wouldn't it squeak regardless of the direction I turn the wheels? I am leaning towards a wheel bearing, but don't really know how to diagnose it. Any thoughts?
1971 C-20 350/350 |
Grandpa in the rustmobile...
Re: incremental squeaking
could a wheel bearing cause alot of break dust?
mines doing the same thing actually...but my brakes are hangin' too, im hopign its a prop. vavle because thats the only old thing on the brake stuff now..
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
Make sure your pads are tight in the calipers and the rattle clips are holding good to the piston. Also put some synthetic brake lube on the back sides of the pads to prevent vibration the leading cause of brake noise.
Fuzzy |
hey hayhauler, why do you think mine only makes noise while turning to the left? I feel like brakes would make noise all the time...
1971 C-20 350/350 |
i'd put it up on jack stands with the wheels off and spend the weekend inspecting things and greasing up moving parts and looking for worn components
I'm guessing that if you're unsure of the state of your wheelbearings, you're overdue to pack them. While you're at it, take cdowns advice. I think I'll do the same.
You will get a laugh out of this one..... I had an old Merc do that to me, & had that front wheel off a half dozen times. It would only squeak turning 1 direction, the pads & rotors looked good. After a little harder look, I found a small pc of gravel stuck tween the rotor & the splash guard! You might also check the wheel bearings(as already mentioned). crazyAL
http://community.webshots.com/user/hotrodhorn |
#8 | |
![]() I'll check the wheel bearings too but I am not really sure what I am looking for...
1971 C-20 350/350 |
shock mounts cause squeaks sometimes// the top muont studs loosen up and enlong the mounting holes// just grab hold of shock and wiggle
have you ever greased the balljoints or tierods or any of the aframe bushings? have you checked the brake pads?to see if there"s anything there like brake pad material? service manuals are great tools
71c-10 350/2004r/4:11 lowered3/4 longbed/dead by hurricane MEANING OF DEATH::::: SOMEBODY ELSE GETS YOUR STUFF DONT BELIEVE EVERYTHING YOU THINK TAKE MY ADVISE;I DON'T USE IT ANYWAY Last edited by cdowns; 08-08-2010 at 05:31 AM. |
well, got a few minutes to pull the front wheels....it's the brake pad wear indicator on the left wheel...so it looks like brake pads are in my future.
The wheelbearings seem tight and have plenty of grease, so they must have been repacked before I bought the truck in March. Since I will be doing pads, i might as well get the rotors turned, and at that point I will repack the wheelbearings again to keep the service interval. Also, I noticed my upper balljoint on the left side is riveted not bolted, so it must be the original?? Might have balljoints in my future too... ...and, the service manual is in the mail ![]() Thanks guys
1971 C-20 350/350 |
#12 | |
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
