08-06-2010, 01:16 AM | #1 |
installing driveshaft into turbo350?
i must be missing something and need your help. trying to put the drive shaft back onto the turbo 350, and it goes about an inch and that's it. i know the drive shaft has a spleen section, but can't seem to find the matching location on the tranny. what am i missing?
does it require some friend taps of a mallet? any other tricks to try? thanks |
08-06-2010, 02:34 AM | #2 |
Re: installing driveshaft into turbo350?
I had the same problem with mine. I wailed on mine with a hammer and had no luck. Almost never got it back off.
Then I discovered the "Master spline" as I called it. You can feel a pair of raised splines on the tailshaft. Mark where it is on the tailshaft. Then feel the slip yoke there will be a notch. Mark it. Simply align your notches and it should slide right on. Lube with trans fluid for a little help also.
1970 Gmc Grande Sierra Swb 2wd LSX (LQ4/4L80e) 1990 K1500 Daily |
