Old 08-06-2010, 11:31 AM   #1
BoeJaker1976
calibrating speedo
Ok, i went down in tire size, and now my speedo is reading 10 MPH faster than i am going. I pulled the driven gear and its has 19 teeth (yellow) and moved the output shaft on the tranny so i can see the drive gear, its green. by the way its a th350 tranny
i have 2.73 rear
with 275/50 r17's
Which driven gear should i go with? do i need to go up in gear teeth? or down? im confused.
Since im here, whats the oil capacity needed for the 350 (might as well change the tranny oil filter and fluid since im there)
1976 Red chevy steppy,
Proud service member, US ARMY
15Y, AH-64D Apache Longbow Armament, Avionics, Electronics technician
BoeJaker1976 is offline   Reply With Quote
Old 08-06-2010, 05:46 PM   #2
joe231
joe231's Avatar
Re: calibrating speedo
According to TCI, yellow driven gear is 41 teeth, the 19 tooth is natural colored
I inputed your data and it says you need a brown 18 tooth driven gear with a green 9 tooth drive gear...doesn't really jive with what you are saying...
http://www.tciauto.com/Products/Tech...eedo_gears.asp
http://chevelleengineer.home.comcast...eer/speedo.htm
CHEVY ONLY
Old 08-06-2010, 07:34 PM   #3
CheyenneC20
I had the same issue with my C20 with turbo 400. I found a 4 teeth change at the driven gear made a 10mph change at the speedo.
CheyenneC20 is offline   Reply With Quote
Old 08-06-2010, 07:36 PM   #4
CheyenneC20
more teeth on the driven gear will slow it down
Old 08-06-2010, 09:39 PM   #5
S10Fan
Old Heap Driver
Contact these folks........................
http://www.transmissioncenter.net/
_____________________________
Bryan
'99 Silverado 1500, 4.3, 5-speed, reg cab, short bed
'50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser.
'40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver.
S10Fan is offline   Reply With Quote
