Old 08-06-2010, 01:04 PM   #1
HSkinner
Newbie with questions about my 66
Well, here I go again. I recently picked up a 66 long bed 1/2 ton. It's currently set up for a manual trans but the trans was removed. I'm thinking about putting a 700r4 in it. Do I have to change the pedal assembly or just remove the clutch pedal. Also, the front end already has 83 suburban front A arms and disc breaks but the rear is stock. so I have 5 lug up front and 6 lug in the rear. I have a 1/2 ton rear axle out of a mid 80's burb but is there an easiear way to change that axle to a 5 lug and keep the factory housing? Also, I read a really good right up on shortening the bed and frame on these trucks but I can't seem to find it again. Thanks, Heath
HSkinner is offline   Reply With Quote
Old 08-06-2010, 10:41 PM   #2
HSkinner
Re: Newbie with questions about my 66
whats a guy gotta do to get some answers.....
Old 08-06-2010, 10:57 PM   #3
forestb
forestb's Avatar
I don't know about the trans swap but as far as the brakes go if you are ok with 6 lug you could pick up some 6 lug front rotors and not have to deal with it. That is of course if your ok with the stock rear end. Or you could get 5 lug rear axles. I think CPP sells them both.
forestb is offline   Reply With Quote
Old 08-06-2010, 11:14 PM   #4
geezer#99
geezer#99's Avatar
Smile Re: Newbie with questions about my 66
You gotta be patient!!! Only us old retired guys are around all day.
geezer#99 is online now   Reply With Quote
Old 08-06-2010, 11:15 PM   #5
C10Slim
Just remove the clutch pedal and linkage. You will also need a new trans crossmember. I just made this swap my self.
C10Slim is offline   Reply With Quote
Old 08-07-2010, 12:53 AM   #6
HSkinner
Any info on the frame and bed shortening? Sorry, I'm a little impatient.
Old 08-07-2010, 01:10 AM   #7
Captainfab
60-66 Nut
You can purchase aftermarket 5 lug conversion axles from, CPP, ECE and Summit racing. Or you can install the mid 80's rear end you have, but it will require cutting and welding to accomodate the trailing arm suspension. Plus that rear end is 1.5" wider (.750" per side)than your original rear end. That may or may not be an issue depending on what tires and wheels you plan to run. You can also convert to 6 lug front discs if you would like to stay with 6 lugs.
You can use an auto trans crossmember from a '66-'87 pickup, 2wd Blazer or Suburban. You will have to remove the original bellhousing crossmember when converting to an automatic transmission. Just remove the clutch pedal.
Sorry but I don't have a link to the thread on shortening a frame and bed. I would imagine that markeb01 will have it saved, an will likely post it. Basically you remover 12" of frame from under the cab, and trim 8" off the back. On the bed you remove 12" just behind the front of the bed, and 8" from behind the wheels. Right at the tailight panel at the rear of the bedside would be best.
Old 08-07-2010, 01:27 AM   #8
HSkinner
Is there a specific year or 6 lug rotors that I would use for the front if I was to leave the rear axle as it is? Thanks again for all of the help. I've benn putting alot of thought inot this and I think I want to start tomorrow. I don't usually build 2wd trucks. I just finished a square body eighties style chevy crew cab that I shortened to a short bed and put a cummins in. I'm ready to build a poor boys hot rod and it appears this is the site for info. Thanks
Old 08-07-2010, 07:23 AM   #9
skysoldier173rd
skysoldier173rd's Avatar
On the bed shortening, the TV show "Trucks" on Spike TV did a 66 bed shortening project on their show last year. They did it all live and quite detailed. Their videos can be had by episode via spike I believe for a nominal fee. A lot better than pictures or written directions.
www.picturetrail.com/skysoldier173rd
skysoldier173rd is offline   Reply With Quote
Old 08-08-2010, 12:48 AM   #10
Captainfab
60-66 Nut
This thread will tell you most anything you want to know about converting to front disc brakes......including what factory 6 lug rotors to use.
http://67-72chevytrucks.com/vboard/s...ght=disc+brake
Old 08-09-2010, 12:58 AM   #11
HSkinner
I wish I could find that link to the classic truck site where they shortened a 64. Anyway, any recomendations on the most cost effective way to lay frame with a 64 swb. It just so happens that I live about 2.5 hours from porterbuilt street rods. I new nate porter long before he became the "go to" suspension guy that he is now. I would rather not spend that kind of money if possible but I may go to his shop and get a look see...
Old 08-09-2010, 11:01 AM   #12
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Here you go...
http://www.classictrucks.com/tech/cl...uck/index.html
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 08-09-2010, 02:10 PM   #13
HSkinner
Thats the one, Thanks
