Old 08-06-2010, 10:48 PM   #1
JCA1972
JCA1972's Avatar
2004 Silverado seats in my 71
Well I finally got my seats in, 2004 Silverado seats and console. The old bench seat wasn't comfortable on long rides.
Now I just need a tilt column and a new steering wheel. Man just when you think youre done, you find out that you want to add something else. Its never ending.
1971 C-10
2004 Yukon:
1998 Honda Accord
2008 Honda Civic
2004 HD V-Rod
http://67-72chevytrucks.com/vboard/s...d.php?t=226458
JCA1972 is offline   Reply With Quote
Old 08-06-2010, 10:50 PM   #2
srea76
srea76's Avatar
Re: 2004 Silverado seats in my 71
Look a lot more comfortable. I will take that bench. Let me know when you can drive to Georgia and drop it off
1972 Custom Deluxe LT1 Gen V Swap "Green Lantern"
1984 Silverado
Red Baron-72 c10 Project
srea76 is offline   Reply With Quote
Old 08-06-2010, 10:52 PM   #3
JCA1972
JCA1972's Avatar
Yeah it is comfotrable, Bench is already sold and gone.
1971 C-10
2004 Yukon:
1998 Honda Accord
2008 Honda Civic
2004 HD V-Rod
Old 08-07-2010, 12:10 AM   #4
red71cheyenne
Back in the sticks
red71cheyenne's Avatar
Those look good in there! How did you end up mounting them?
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection
1969 K5 Blazer w/Tuned Port
2010 2SS/RS Flaming Orange Camaro
2011 K1500 Suburban
2014 K1500 Pickup
2008 Nissan Altima? The wifes' hoopty
red71cheyenne is offline   Reply With Quote
Old 08-07-2010, 01:17 AM   #5
redmonster
redmonster's Avatar
seats look great
redmonster is offline   Reply With Quote
Old 08-07-2010, 01:46 AM   #6
Ackattack
Ackattack's Avatar
I have seats from a '02 Tahoe with manual lumbar support. With the lumbar "turned all the way down" it still feels like there is a log behind me. Never felt that in my suburban or pickup that had power lumbar.
Ackattack is offline   Reply With Quote
Old 08-07-2010, 02:37 AM   #7
Dingfodgy
Lemme show you something!!
Dingfodgy's Avatar
I had the same seats except in cloth in my '67.....loved 'em! However, the backs are a bit thicker than the stock bench seat. To avoid having to scrounge up a decent tilt column- I just did the column mod that moves the steering wheel closer to the dash by a couple inches. It made all the difference- even with my 250lb. fat a$$, I could get in and out just fine.
'67 CST-10 LWB ("Crusty") SOLD
'67 GMC SWB ("Murdock")
2000 K1500 Suburban ("Betty")
'95 BMW 325i ("Joy")
Dingfodgy is offline   Reply With Quote
Old 08-07-2010, 06:03 AM   #8
Andy4639
Old member
Andy4639's Avatar
Talking Re: 2004 Silverado seats in my 71
The seat's look great! Is the steering wheel that close to the drivers seat or is it the picture angle? Did you hook up all the he electrics on them? I like my heated seat in the Tahoe wish my 71 had it!.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 08-07-2010, 09:25 AM   #9
JCA1972
JCA1972's Avatar
I used 3/8 bolts with 1/2" washers on the bottom. That's the angle of the pic. The seat is not that close to the steering wheel. I only hooked up the power to the seats, I don't need heated seats in Houston.
1971 C-10
2004 Yukon:
1998 Honda Accord
2008 Honda Civic
2004 HD V-Rod
Old 08-07-2010, 09:49 AM   #10
Andy4639
Old member
Andy4639's Avatar
That's good! Yea if in Houston I guess not. Do you have enough room for the seat to lay back at all? They look great and they look good and confy to!
Old 08-07-2010, 08:00 PM   #11
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Just so I understand... the bolt holes didn't line up with the existing mounting holes, so you drilled new holes in the floor and backed them up with large washers?
Those do look great, and look a lot more comfortable!
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 08-07-2010, 10:16 PM   #12
JCA1972
JCA1972's Avatar
Yes That is a true statement.
1971 C-10
2004 Yukon:
1998 Honda Accord
2008 Honda Civic
2004 HD V-Rod
Old 08-08-2010, 06:15 PM   #13
StepSideRick
StepSideRick's Avatar
Thank's Dingfodgy thats good to know,I need a seat and that looks nice.
StepSideRick is offline   Reply With Quote
Old 08-07-2010, 10:41 AM   #14
Pop's C-10
Pop's C-10's Avatar
Thoese look sweet....
Pop's C-10 is offline   Reply With Quote
Old 08-07-2010, 11:20 AM   #15
BIG ORANGE
BIG ORANGE's Avatar
I have those seats in my 2004, and there comfy! Yours look great in yr truck!
Things happen for a reason!
BIG ORANGE is offline   Reply With Quote
Old 08-07-2010, 01:46 PM   #16
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
The seats look great in your truck. As soon as I get the gas tank out of the cab which means I have to get my ECE rear mounted gas tank installed which means I need to remove the box and if I do that i might as well redo the wood box floor and on it goes..... I have the same ones ready to go in my 72only they are the cloth ones with power both sides.
In doing some research on installing these seats its been pointed out that the the truck floor should be reinforced. If the floor isn't reinforced the seats could rip out of the floor in an accident. I do believe there have been threads on here showing how some members have reinforced the floor for the seats.
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 08-07-2010, 05:17 PM   #17
StepSideRick
Can those seats be installed with the gastank in the cab?
Old 08-07-2010, 06:50 PM   #18
Dingfodgy
Dingfodgy's Avatar
Yes, I intalled mine with the in-cab tank in place. The seat backs hit the kick-out under the rear window long before they would make contact with the gas tank.
Old 08-08-2010, 09:01 PM   #19
JCA1972
JCA1972's Avatar
Here is a pic of what took place of the gas tank.
1971 C-10
2004 Yukon:
1998 Honda Accord
2008 Honda Civic
2004 HD V-Rod
Old 08-09-2010, 09:06 PM   #20
HeavyD
HeavyD's Avatar
Much difference in legroom?
"You can take the man out of PA, but you can't take PA out of the man"
HeavyD is offline   Reply With Quote
Old 08-09-2010, 09:18 PM   #21
JCA1972
JCA1972's Avatar
Not really, I'm 6'1", I don't think that they made these trucks for tall guys.
1971 C-10
2004 Yukon:
1998 Honda Accord
2008 Honda Civic
2004 HD V-Rod
Old 08-09-2010, 09:56 PM   #22
DustyC10
I was afraid you were going to say that... Im 6'3", I have a feeling finding the right seat is going to be interesting...
DustyC10 is offline   Reply With Quote
Old 08-29-2010, 11:47 AM   #23
JCA1972
JCA1972's Avatar
Let me know if you find one. LOL
1971 C-10
2004 Yukon:
1998 Honda Accord
2008 Honda Civic
2004 HD V-Rod
