Old 08-07-2010, 12:26 PM   #1
keanevann
71 axle swap....6 lug to 5 lug
I have two 71 chevy axles....one is a leaf spring rear end and one is a coil spring rear end..... The leaf has 5 lug and the coil has 6 lug..... I need 5 lugs on the coil..... I know the older rear ends are narrower but can I just swap the axles since they are the same year and everything?? I searched but i didnt find the info I was looking for.....Maybe one of you guys with some knowledge can help me out? Thanks guys!! Keane
keanevann is offline   Reply With Quote
Old 08-07-2010, 01:25 PM   #2
truckpoorpackrat
Re: 71 axle swap....6 lug to 5 lug
If the axle length is the same they will interchange otherwise no. James.
truckpoorpackrat is offline   Reply With Quote
Old 08-07-2010, 02:18 PM   #3
keanevann
Thats what I am asking....is there a difference between the rear ends other than the lugs? There both date coded 71.....is there any reason they would be different lengths???
Old 08-07-2010, 02:40 PM   #4
cdowns
cdowns's Avatar
the 6 lug rear is not a 71
Old 08-07-2010, 03:09 PM   #5
nightmare
nightmare's Avatar
really, the best thing to do would be to remove the axle shafts and measure from a base point on both. if they match up, then there shouldn't be any problems switching them.
Mike
2001 Dakota R/T - Silver CC - 1 of 1671 •360 w/46RE •392 limited slip
1972 Chevy Suburban - Turquoise/Black
1969 Chevy C/10 - Blue LWB •350 w/ 700R4 •3.73 posi •PS PB A/C - SOLD
Using your turn signal is not "giving information to the enemy"
67-72 FAQ
Originally Posted by GMCMAX View Post
My lugnuts require more torque than your honda makes!
nightmare is offline   Reply With Quote
Old 08-07-2010, 04:19 PM   #6
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
i'm trying to figure why a 71 coil rear would have 6 lugs... the leaf rear could easily be a 4x4, and that would dictate 6 lugs...
something doesn't add up.
Pull the shafts. If they are the same length, then swap them. If they aren't, then put them back.
