Active Member
![]() Join Date: Oct 2002
396 Turbo Jet accelerator linkage
Can someone please tell me what is missing from my 396 accelerator linkage?
To the right of the linkage is the kickdown swicth. What is the swith to the left of the linkage ? Also what is missing to hold the rod in place? it has a little cotter pin but there has to be something more If anyone has the parts to sell please let me know. |
![]() Join Date: May 2007
Re: 396 Turbo Jet accelerator linkage
There is supposed to be a little metal piece, that attaches to the throttle linkage arm of the carb. It kinda looks like a flat piece of metal that was bent into a 90 degree angle. It pushes against the kickdown plunger. The other thing is your idle solenoid. When you turn on the A/C, the plunger pushes on your throttle arm to increase the idle speed, due to the extra load from the compressor.
Turp Mcspray New life for an old 2wd, farm blazer http://67-72chevytrucks.com/vboard/s...d.php?t=505987 My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299 |
![]() Join Date: Apr 2007
If you search "kickdown" in parts board you will see pics of the piece you are missing posted by LIVRAT and CPNE. Sharpie
Active Member
Thanks for the help guys, but I searched the board and I cant find the post.
member #16
![]() Join Date: Dec 1999
Heres a pic. The linkage looks somewhat different. Possible carb change in the past?
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors ![]() http://www.flickr.com/photos/1745471...7602865984234/ |
#6 | |
Active Member
But the rod on mine is not the same as yours. The carb is a rebuild unit, my accelerator rod is the same as the one that board member too much stuff has on his 1969, 396. Mine is a 1968, what year is yours? |
Guys, I'm gonna move this to the '67-72 message board - that's a better place for it.
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD ![]() Click here to support the board Philippians 4: 6-7 |
Chemist under the hood...
I'd check to see that it's the right carb for your truck. I swapped in a new carb on the weekend and even though it was the exact same model number, it had a different throttle arm so I had to rig up something for it to work with my throttle linkage.
Over the years, people have changed manifolds and carbs. Mine should have had a 292 inline six with a two barrell carb. It had a '67 283 V8 in it with a quadrajet 4MV when I got it. That engine should have had a Rochester 2G but someone changed the intake manifold so it could have a 4BBL. I put another rebuilt quadrajet in but it was probably from a car instead of a truck so the linkage had to be modified. Good luck.
Current fleet: 2013 GMC Sierra, 5.3L, 4x4 1988 GMC Sierra, 305, Auto 1984 Jeep Grand Wagoneer, 360 V8 1997 VW Cabrio, 2.0L 2017 Toyota Rav4, 2.5L Stuff I wish I still had: 2013 Toyota Matrix [RIP] 1967 GMC 910 Fleetside, 283 V8 [1st Love-SOLD] 1987 Jeep Cherokee Laredo 4X4, 4.0 I-6 [SOLD} 1994 Chevrolet Caprice Classic, 5.7LV8 [SOLD] 1995 Chevrolet Astro AWD, 4.3L V6 (RIP) 1998 Chevrolet Suburban 4x4, 5.7L V8 [SOLD] |
