08-07-2010, 07:11 PM | #1 |
dome light door switch
I am needing to add dome light switch to 3rd door. I have the new switch but do I need a nutsert or something to screw it into. I was thinking maybe I could just drill a hole and screw the switch in but not so sure this will last without working its way loose.
http://www.picturetrail.com/jwill41 67 1/2 ton GMC short step side 68 1/2 ton Chevy long fleet side 72 1/2 ton Chevy Suburban 99 1/2 ton Chevy Suburban founder (and only member) of the primer/clearcoat club |
08-08-2010, 08:13 PM | #2 |
Re: dome light door switch
For anyone else wanting to do this, there are couple of layers of metal this area so I drilled and tapped it and it worked perfectly.
08-09-2010, 01:58 AM | #3 |
That is slick! Nice work and great idea.
08-09-2010, 08:21 AM | #4 |
ran the wire down inside door jamb and under the sill plate to the dome light wire next to glove compartment. Now my alarm works on all 3 doors. The rear hatch is next.
