![]() Join Date: Dec 2008
trailing arm perch location
with the trailing arm perches properly spaced what is the distance between the front holes side to side and rear holes side to side?
Re: trailing arm perch location
Did you ever get this answer? Also did you ever finish your trailing arm conversion.
Long live SLIM ------------------ At least try to buy American ![]() |
Updates?
1982 Silverado - SBE, cleaned up GM heads, small cam, TH350, 850 Demon, 4.56 gears, and caltracs. Best time so far 11.8@XXXMPH |
Its a Truck Thing......
I have an axle on jackstands if anyone still wants this info, its for trailing arms.
Smitty
71 C10 283/3SPD Full Resto 71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599 70 C10 Suburban Former military GSA truck. 72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378 72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110 68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head 71 C30 Wrecker 71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck 68 GMC Long Stepside. They keep following me home 71 C20 Longhorn/Ole Yellor 69 C30 Former Motor Home, Flat Bed time |
I'd like to know. Thanks.
I measured & put some dimensional data up before for both a 71/72 housing & a 68 housing. I've been looking but can't find where I put the info....
