Old 08-08-2010, 09:15 AM   #1
fred1968
How to?
When changing from a 3 row rad to a 4 row you need to replace the upper and lower supports. Are the lowers welded or bolted in place?
fred1968 is offline   Reply With Quote
Old 08-08-2010, 09:19 AM   #2
jay6891
Car Knocker
jay6891's Avatar
Re: How to?
I believe mine were bolted into place with 5/16" bolts. 71 model chevy.
68 c-10,91 sportside bed,350 .030 over,4 bolt,10-1 comp,2.05 intake/1.94 exhaust,1.6 Harland Sharp roller rockers,edelbrock rpm cam and intake w/750 carb, 700r4, 3.73 gears,Jacabbs Electronic Igntion w/Accel HEI distributer and super coil. ZR-1 roll pan, filled tailights. Blazer tank. Hidden hitch. 2 1/2" Flowmaster 40's. Parts bought but not installed>> ford 9" posi with disc. CCP front and rear lowering kit 4/5. Cab corners,foor boards,rockers, cab braces, Phatom grill, Painless wiring kit.
jay6891 is offline   Reply With Quote
Old 08-08-2010, 10:05 AM   #3
Alex Hayley
Re: How to?
Mine were riveted. I used little button head bolts to put the new ones in.
Alex Hayley is offline   Reply With Quote
Old 08-08-2010, 02:25 PM   #4
grs
Re: How to?
I changed from a 3 row to a 4 row. I did not have to change the supports. I had to change the rubber supports. I had to cut them a little to get it to fit.
grs is offline   Reply With Quote
Old 08-08-2010, 02:52 PM   #5
67ChevyRedneck
67ChevyRedneck's Avatar
Re: How to?
As were mine and I did the same thing.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 08-08-2010, 02:53 PM   #6
71swb4x4
71swb4x4's Avatar
Re: How to?
Mine was riveted in. My original radiator was narrower than the new, so I had to move that lower support out to the wider position. Went from a 6 cylinder single row to a three row.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
