SSN 706
airlines to front bags?
Pics of how you ran your front airlines to your bags? Doesn't seem to be a good way?
Re: airlines to front bags?
I wen t straight down through the spring pocket and droped into the top of the bag.
Troy 1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884 Big Red Dog build http://67-72chevytrucks.com/vboard/s...d.php?t=572274 |
SSN 706
So you drilled a hole? or out the crossmember? I did'nt any pics in your thread. Trucks getting there though.
![]() ![]() ![]() ![]() ![]() ![]() ![]() Last edited by daverod; 08-08-2010 at 03:52 PM. |
Ill go get you a pic....
Here you go.
SSN 706
i used 90 degree fittings on the bags and ran them through the cross member to the passenger side and out through an unused hole
Mine run through the front crossmember with 2 holes in the rail (w/ grommets of course), 90's on tops of the bags. They are T'ed at the instruments.
I did this because I wanted F+B not FBSS and doing it at the 1/4" lines slowed the air down a bit so I didn't get crazy roll in turns. Also, if I ever need to change it (when the new crossmember is installed) then it is easier to change.
This statement was made possible by a grant from this station and continued support from viewers like you. Flickr |
