Replacing the Cab Mounts
I'll be doing cab mounts for the first time on my 70 step,and was wondering if it's as straightforward as it seems and are there any tricks anyone knows thanks Rick
Grandpa in the rustmobile...
Re: Replacing the Cab Mounts
lol probably dont plan on reusing the old bolts..lots of pb blaster....ive never done it just guessing
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
No oldblue I bought a urethane kit with all bolts.washers.etc.The mounts are so bad you can turn them with your hand so PB blaster won't help bot a cut off wheel will
Hi, You don't have to remove the gas tank for the rear, the rear bolts screw in from the bottom, if I remember right. Good luck taking out the old front bolts.
1971 C-10 2004 Yukon: 1998 Honda Accord 2008 Honda Civic 2004 HD V-Rod http://67-72chevytrucks.com/vboard/s...d.php?t=226458 |
Thanks for the good news JCA,Get those front bolts out and it will be a breeze.Those famous last words
when i put all mounts on mine i left tank in... i dont know if you can do what i did.. when i slid in my new urethane whatcha call its i crawled underneath and put my knees on the floarboard and lifted up and slid each piece in piece by piece but im a young lad... but ya its really straight forward
1972 C-10...402/400..flowmaster 40 series 1967 Mustang 347 stroker/C-4 1966 Mustang 289/3-speed 2013 Mustang V6/6speed w/300 ponies I may be 23, but i sure do knows 67-72s are sexy! Its not MPG its smiles per gallon! build started 11/25/08 build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796 |
#7 | |
lol i woulda used floorjack too and imma young lad, unless i was in a hurry then i woulda picked er up, or tried..ima scrawny lil fella
ya i didnt feel like digging in my garage when i did mine... we got my truck, 66 mustang,67 mustang, dads harley, and a 347 stroker on engine stand that i just finished building all sitting in a two car garage so i just did mine the hard way by using my knees and pushing up haha that jack is in the mess and could take days to find haha
if you go to lmctruck.com and go to the cab mount section on their online catalog it will show you a pic of how each piece fits in
#13 |
Under Construction
FYI, most of the front bolt head were tack welded to the cab from the interior. Try removing the nut first, then you can break the tack to remove the bolt...
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
#14 |
#15 | ||
![]() ![]() Quote:
#16 |
Project '67 454
Compare the new spacer sleeves to the originals to make sure they are the same length.
The factory front ones on my '67 were shorter than the rear but the kit I got came with the same size for the front and back. I didn't catch it until many months later when I couldn't get the front end to line up correctly with the cab and doors. Luckily I still had the originals in a box and realized what I did.
67 C-10 SWB Fleetside 454 (current project) ![]() 99 Crewcab SWB Dually 454 ![]() 75 Datsun 280ZZ430 ![]() 94 Formula 232LS 454 ![]() |
#17 |
Thanks to everyone for the useful info.This forum is such a great place to learn about our trucks.It makes going into a job that much easier having advice from people who have done it before.This place ROCKS
#18 |
Just replaced my cab supports on my 72 and like My67truck said they were spot welded in and they were a pain to get out.I had to take a ziz wheel and cut down in the bolt head trying to keep from cutting the floorboard.
#19 |
ya sorry i forgot about the tack welds in floorboard.. i air chisled my front supports off and it came threw my floor so i had to put new floor pans in and that little tid bit phased me but ya they arnt to bad to cut
