Bell Tech flip
I just installed the flip on my 83 1/2 ton. Wanted to make sure I did it right. It said to put the offset hole on the saddle toward the front of the truck basically moving the axle back. Is this correct?
Also I installed the c-notches using the pattern they provided but they seem like they are not directly above the axle. It is off the ground though so maybe it will line up better once there is weight on it. |
| Bookmarks |
