08-08-2010, 10:18 PM | #1 |
Cummin Swap Info
I am looking for some more info on the Cummin Swaps. I been lookin on the board and reading the ones that been done but I am looking for more info on different cummins. I been looking at 4bt and 6bt since I have 5 of them in my area I can snag for cheap but also been reading about the 12v. My main focus/problem is if it will fit in my truck as most trucks I see them in are 4x4 and mine is a 2wd bagged and body dropped crew cab. I Z'd the front and stock floored it 2.75 inches to lay rocker so I want to make sure I can do it. Any info is appreciated thanks.
08-08-2010, 10:26 PM | #2 |
Formerly- 1972SuperCheyenne
Re: Cummin Swap Info
I am going to say if yours is Z'd and bodydropped you can forget about it. Plus it weighs like 1200 lbs. Do you need it to tow or anything?
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. |
08-08-2010, 10:45 PM | #3 |
I'm with him, good luck with at 12 valve with bein that low, is it possible? yes, but you would have to run probley a 4 inch cowl, cut out your firewall and floor and redo all of that to raise up the engine enough. By the was, all 89-98.5 cummins in the dodges are 12 valves, both the rotary pump and inline pump engines, and all 12 valves are 6bt's, and when they went to electronic injection they went to 24 valves, or ISB's.
88 Crewcab Dually 5.9 Cummins, 5306 Eaton 6-speed, converted 4x4 w/52's up front, 90 front clip(parting out) 1986 ElCamino (needs motor) 1970 C30(future service truck for my ag-equipment repair business) 1970 CST10(parting out and partial donor for the '70 C30) 2000 GMC 1500 ext cab sb, z71, 5.3 loaded auto |
08-09-2010, 09:42 AM | #4 |
and as far as the 4BTs you are not going to be any better off there either as they are the same height as the 6BTs.
08-09-2010, 08:25 PM | #5 |
Okay. I was planning on using the truck to tow our shop projects around when its finished. Guess I will be looking into an EFI motor or dropping in a 355. Thanks for the help guys.
08-09-2010, 08:49 PM | #6 |
Stick a 454 in it and tow away man! Any pics of the truck?
08-10-2010, 09:23 PM | #7 |
No, I unfortunately do not have a camera anymore. It took a swim on a mud ride and I just never got around to getting a new camera.
08-10-2010, 09:32 PM | #8 |
I completely agree. A 454 is what you want and you will never look back.
86 Suburban 2WD = rolled it and totaled it 83 LWB STD Cab 4x4 = went to the scrapper. Was my baby. 84 Suburban 2WD = stripped it/ scrapped it 81 8 foot bed made into a trailer 86 Suburban going to be made into a trailer 91 Suburban 4x4 = that's my baby 00 S10 Xtreme STD Cab 01 S10 ZR2 |
08-10-2010, 09:40 PM | #9 |
BAD BOW-Silverado XST
6.0 or 8.1 will work as good.
08-11-2010, 12:07 AM | #10 |
08-11-2010, 05:08 PM | #11 |
6>8 Plugless........
You have got to be kidding me? A 454? Never look back? How about 400hp and atleast 16mpg not to mention the torque. Then never look back. You can fit the 5.9 in your truck, it might just take some creativity. If I can put one in a 68 corvette and have it under the hood, you can fit one in your truck. You may have to modify the oil pan, and modify the truck's floor pan, but it can be done.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. Last edited by Dieselwrencher; 08-11-2010 at 05:08 PM. |
08-11-2010, 05:57 PM | #12 |
Location: Where I come from, it's cornbread and chicken...
Amen
08-11-2010, 07:31 PM | #13 |
http://www.cumminsforum.com/forum/cu...chevy-2wd.html
read this it might help or else look through the other posts on the site in the cummins conversions section |
