08-08-2010, 11:20 PM | #1 |
Rivets!!!!!
OMG. Just when I thought I was done grinding, cutting, drilling out rivets I'm not. I bagged it, notched it and set the burb down.... Only prob was it was not low enough.... I call Nate order up some more stuff. So now I'm prepping the burb for round two. Spent a few hours working on rivets...... I hate these things!!! Lol. Got 7 more to go and I'm done, I can't wait. Now clean, sand, paint and wait for UPS to get here! Pics in a couple of days guys.
Later
68 BB burb build thread Scott's super slam front/rear http://67-72chevytrucks.com/vboard/s...d.php?t=378084 |
08-08-2010, 11:23 PM | #2 |
Re: Rivets!!!!!
whats your method to the madness of removing em?
08-08-2010, 11:48 PM | #3 |
Re: Rivets!!!!!
Grind heads down then drill out.
08-08-2010, 11:55 PM | #4 |
Truck and auto performance nut
Re: Rivets!!!!!
I've found I can cut the heads off with my sawzall faster then my grinder takes one down...then beat the crossmember (or other part thats connected), or the frame with my BFH...usually the rivets pull out enough to let go. Then after I get it off the part... the rivets will usually pop out with a BFH and a punch.
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
08-09-2010, 12:10 AM | #5 | |
Laid Lo
Re: Rivets!!!!!
My back hurts though!
Semper Fi, Jeff '72 C10 - lays frame '07 Sand Rail - ecotec powered '05 2500HD - tows stuff '67 VW Bug - gas saver '01 Jeep TJ - rock crawler |
08-09-2010, 12:17 AM | #6 |
Re: Rivets!!!!!
I had to remove a ton of these on my truck as well. I put a cutting wheel on my grinder and notched x's on the heads and then cut them off with an air chisel. It wasnt to bad.
08-09-2010, 12:23 AM | #7 |
Re: Rivets!!!!!
my truck has a leaf spring frame...and I'm putting in a coil spring setup...so everything from the center crossmember back is different.
08-09-2010, 12:24 AM | #8 |
Re: Rivets!!!!!
What's making it difficult is that I am doing this with yhe truck on the frame. It's a suburban so no pulling the bed off.
08-09-2010, 01:21 AM | #9 |
Jesse
Re: Rivets!!!!!
Oh man i here you, i just got done this weekend gutting my 63' frame of all 3 cross members and plates. I cut rivets for 2 days with the cab on. I put a 1/8" thick cutting wheel on my grinder and would cut the heads off on both sides then punch the rest out with my air hammer, except for the trailing arm cross member i just cut of the inside rivet heads and hammered the crap out of them to push them out the top. It was loud and im sure my neighbors hate me now Now i'm mocking up my PB trailing arm kit.
08-09-2010, 10:24 AM | #10 |
Re: Rivets!!!!!
cut off as much of the head as you can with a cutoff wheel, then use a sanding disc so sand the rest of the head off then use a punch or screwdriver or something and hit it with a hammer and they seem to come right out, that how i did it anyways
08-09-2010, 11:16 AM | #11 |
Re: Rivets!!!!!
This is what I did when I bagged my truck. I tried several ways, and this worked best for me. Having an air hammer really sped things up. The ones on the center crossmember under my cab were the worst, took about 2 to 3 hours to get all of them out, and was loud as hell. It was about 10 at night when I started on those, so I know my neighbors hated me. Thank god I had a shop to work in instead of out in the open, of I know I would have had a visitor telling me to quit for the night. Good luck getting yours out.
08-09-2010, 12:16 PM | #12 | |
Re: Rivets!!!!!
That's how I did all of mine (probably 7 or 8 different trucks). BTW - when I ordered my '87, I knew I was going to be lowering it. As I was following it down the assembly line I asked if I could use 3/8 bolts instead of rivets for all the spring hangers (that's the "in plant" repair procedure). They said no. Would've saved a ton of work. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 08-09-2010 at 12:16 PM. |
08-10-2010, 01:41 PM | #13 | |
Re: Rivets!!!!!
08-10-2010, 10:36 PM | #14 |
Grandpa in the rustmobile...
Re: Rivets!!!!!
saved this that another member posted...
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
08-10-2010, 10:43 PM | #15 |
someday it will be done!
Re: Rivets!!!!!
^ lmao
'72 C-10 Proud owner of a million new and used pieces that used to be and will once again be(god willing) a testament to the term "they don't build em like that anymore. '80 LWB 2wd beater '67 GMC long fleet (cab donor) '66 long step (parked till it's turn comes around) '65 short step (parts truck that will donate it's bed and possibly frame to the '66) '06 Grand Prix wife's car (she hardly lets me touch it) my pics |
08-11-2010, 12:12 AM | #16 |
Re: Rivets!!!!!
I got something for those m&@:$) f$&@ rivets. Will post pics tomorrow. Lol
