which rearend to use?
alright so i currently have a 12 bolt in my truck with what i beleive to be 4.11 gears all i know is with the straight six and my foot to the floor and the engine redlining itll go 80 i got it to 85 once with a wind at my back and down a hill i just found a 68 rearend with 3.73s and its a coil spring like mine ive been wanting higher gears do u think that this would work out or does anybody have an idea what my gears are just by guessing any help would be appreciated
1966 chevy 1/2 ton freshly rebuilt 350 stock cam performer intake 600 cfm edelbrock 4spd behind it 1986 chevy 4x4 1/2 ton 350 700r4/208 2in lift blocks 31 at tires |
60-66 Nut
![]() ![]() Join Date: Mar 2007
Re: which rearend to use?
Before you get any further, I would suggest pulling the cover on the rear end in your truck and see exactly just what you have. You may already have 3.73's. Either way the oil in a rear end is one of the most neglected vehicle fluids. It could probably stand to be changed. And when you go to get some gear oil, don't forget to get a new rear cover gasket. If you already have 3.73's, they next step up is 3.42's. Also stepping up to a taller tire will help a little.
Airport Bum
I put a '68 Posi in my '64.
It was plug and play. Higher gears made it actually driveable on the freeway.
1964 Chevrolet C-10 1941 Chevrolet coupe 1962 Thunderbird 1959 Edsel Villager 1963 Skylark |
3.73 was the most common rear in these trucks. 4.11 came standard with manual overdrive or could be ordered as an option by itself. You don't see very many 4.11s though, so I'm betting you have a 3.73.
If you want the truck to be quiet at highway speed with no overdrive, you should probably be looking at a 3.07. Ray |
#5 | |
Rollin' Old Skool
ok my rear end is going out and it's time to upgrade and replace. i would really like to put star wires on my truck. so car small five lug would be great. i can weld that is no big deal. and i cant even find a truck rear around here. so what cars should i be looking for as a donor?
#7 | |
I hope this helps! Last edited by lakeroadster; 08-11-2010 at 06:38 PM. |
#8 | |
Resistance is Futile
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
#9 | |
Ray |
ok thanks guys. does anybody sell perches?
Here is a kit with the trailing arm brackets and panhard bar.
http://www.classicperform.com/Store/...ck/6072RCK.htm CPP also sells the trailing arm brackets separately. http://www.classicperform.com/Store/...ck/6072RAS.htm Ray |
My 66 had the 250 inline six with 3.73 rear end it topped out max at 82mph. That was it, I don't think you have a 4.11 rearend but I could be wrong.
#13 | |
60-66 Nut
If you could find one out of a mid to late '60's Chevelle/Malibu/El Camino, they are about 1" narrower than your original rear end.
