Old 02-21-2003, 06:58 PM   #1
moose
Vortec ?????
there is local salvage yard that has 02 vortec that only has 8000 miles on it they will take 1350.00 complete with computer, fuelinjection, alternator,ect. Is that werth it and if so will that block bolt up to 350t? what other little thing will I need like fuel pump I know. would like to run the fuelinjection insted of just carb. I may be over my head on this on but can't a man dream. thanks Moose.
69 C/10 swb coming along slow but sure 4 yr and counting Omaha Nebr
7I JIMMY 350 4speed daily driver/next prodject
99Yukon wifes
moose is offline   Reply With Quote
Old 02-21-2003, 10:17 PM   #2
lukecp
Formerly yellow72custom
lukecp's Avatar
If it is a 4.8, 5.3, or 6.0 litre vortec motor, it is completely different than the old small blocks we are all familliar with. There isn't even a distributor on one, it has one coil per plug wires. The new Vortec motors are basically a iron version of the LS1/LS6 motors in the Corvette, Camaro, and Firebird. I read an article in Popular Hot Rodding a few years ago about upgrades about the LS1, and they showed a picture of the bellhousing on one. They said the bolt pattern was the same, but all the fastners were metric, and one extra bolt was added at the top. While i think that 1350 is a great deal for that motor, it would be a real bear to put in your truck.
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride.
'70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck.
'97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg
lukecp is offline   Reply With Quote
Old 02-21-2003, 11:09 PM   #3
adamls
Gotta Startem Early
adamls's Avatar
Man I wish I could find something like that. The fuel injection is worth that even if you do not use the engine. I say go for it. If not let me know I would be interested in shipping it my way.
67 SWB In Progress, one piece at a time, maybe 3 years I will be finished
adamls is offline   Reply With Quote
Old 02-22-2003, 01:02 AM   #4
jmil1974
Ain't we cute?
jmil1974's Avatar
Which vortec is it? The 4.8, 5.3, or 6.0? Get the tranny too if you can, that will make it MUCH easier for you and OD to boot. Hell, make an offer for the whole truck so you can use the gas tank/pump too. Now you're talking VERY do-able. Check out www.ls1tech.com Awesome price, btw.
69 C10 2WD LWB Fleet 350/350 power front disc conversion (6 lug disc kit from gmcpauls) and new engine, PS, A/C, fresh fluids, SHE DRIVES!
FOR SALE $3900
jmil1974 is offline   Reply With Quote
Old 02-22-2003, 02:50 AM   #5
moose
Did not know there was so many different size motor in the full size tahoe will have to look in to witch size it is. I f it is a 8cylinder will the heads fit on a older block or is there a bolt pattern issue there to. problem with buying complete truck is no room and the wife would divorce me for something like that and I don't want that!!!!!!!!! need automatic for the 69 two wheel drive the truck is 4x4 that it coming out of. please forgive my rambling I have had to many rum and cokes
enjoy MOOSE
99Yukon wifes
Old 02-22-2003, 03:21 AM   #6
adamls
Gotta Startem Early
adamls's Avatar
Full size Tahoe most likely will come with a 5.3 liter. Factory 320 HP, you could probably bump that up to around 350 with headers and dual exhaust, cold air intake and computer tuning. The heads should fit an early model block but not just any intake will fit the heads. As for the transmission it will still work in your 2 wd if I am not mistaken just remove the transfer case, install tailhousing. Gas mileage, fuel injection, overdrive, new engine.
Old 02-22-2003, 06:12 AM   #7
Project1970
14.1 @ 96MPH
Project1970's Avatar
Erm...the GenIII Vortec heads (the 4.8, 5.3, and 6.0) will NOT fit an older smallblock. Not even close. The Vortecs that DO fit are the 5.7L (350) GenI Vortecs.
The fact that the donor is a 4WD and yours is a 2WD would complicate a full swap slightly...in that as far as I know, the 4WD tranny is not set up to bolt to a driveshaft. It will also almost guaranteed need some computer reprogramming, don't forget about that...that's relatively cheap to do when you consider how many things that takes care of (removing unused systems from the computer, bumping timing and fuel maps some, etc)
Project1970 - LS1 Swap Complete!
Project1970 is offline   Reply With Quote
Old 02-22-2003, 12:25 PM   #8
adamls
Gotta Startem Early
adamls's Avatar
My bad, your right project1970, forgot about the Gen1-III thing.
Old 02-22-2003, 02:47 PM   #9
jmil1974
Ain't we cute?
jmil1974's Avatar
The 5.3L has 285HP. The 6.0 has between 300 and 345 depending on what it's out of. I think the 4.5 has 245 or 255. There's a bigger jump in torque than horsepower between the displacements.
FOR SALE $3900
