Old 08-09-2010, 06:29 PM   #1
silvereagle07
silvereagle07's Avatar
What do I need to swap transmissions?
I need to swap the 700r4 in the parts 91 suburban I have into my 84 GMC with 700r4. I finally got around to resolving my driveshaft issue and found out the trans case is busted. I have a 700r4 in the parts sub but I know it can't be straight forward. I just don't have that kind of luck. Any idea's?
Jeramy
'84 GMC project truck
'85 Chevy 4X4 SOLD
'07 Chevy Trailblazer SS
5th Annual SHPHC Car/Truck Show Pics
http://67-72chevytrucks.com/vboard/s...d.php?t=543605 UPDATED PICS! CHECK 'EM OUT
silvereagle07 is offline   Reply With Quote
Old 08-09-2010, 07:29 PM   #2
texasfunk
texasfunk's Avatar
Re: What do I need to swap transmissions?
IF im correct, it should be straight forward, i know the 700r4's changed some from years to others, but not sure what that has to do..
2006 GMC Sierra CCSB, 6.0 swap
2000 Chevy C3500 Crew Cab shortbed dually
1999 Chevy c2500 Crew Cab shortbed
1982 El Camino 350/350
1979 K5 2wd blazer bagged/bodied
1986 Monte Carlo SS
1991 Chevy CK SWB-67 clip and tailgate, bagged 350/700r4
1955 Chevy Bel Air
2014 Chevy Silverado ccsb
texasfunk is offline   Reply With Quote
Old 08-09-2010, 08:56 PM   #3
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
Straight forward buddy! Let me know if I can help you out man.
--Josh
Old 08-10-2010, 07:24 AM   #4
silvereagle07
I thought the 91 version had an electronic speedo. Doesn't that eliminate the cable and gear at the tailshaft?
Jeramy
'85 Chevy 4X4 SOLD
Old 08-10-2010, 08:30 AM   #5
texasfunk
texasfunk's Avatar
hmm, i did a swap a while back into my 82 from a 91, mine had the cable...
1986 Monte Carlo SS
1955 Chevy Bel Air
Old 08-10-2010, 10:47 AM   #6
STOCKISH
STOCKISH's Avatar
Can we not swap the tailshafts?
--Josh
Old 08-10-2010, 11:26 AM   #7
mcbassin
Still Learning
mcbassin's Avatar
I may be wrong but I think you might be able to put your gear drive in the newer one? You might want to post this in the engine and drivetrain area, there are some motor and tranny studs over there that forgot way more than I ever knew about them.
mcbassin is offline   Reply With Quote
Old 08-10-2010, 11:59 AM   #8
cableguy0
The transmission itself is a bolt in. The 700r4/4l60 only came in one length except for the units that came in corvettes. The electronic speed stuff I think will interchange with the mechanical stuff. Just swap them back and forth.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 08-10-2010, 04:58 PM   #9
STOCKISH
STOCKISH's Avatar
And if that wont work, we'll just start on the LSX swap!
--Josh
Old 08-10-2010, 05:34 PM   #10
silvereagle07
Whoaaaaaa! Slow down Josh. I still have the other engine to put in first.
Jeramy
'85 Chevy 4X4 SOLD
Old 08-10-2010, 09:57 PM   #11
STOCKISH
STOCKISH's Avatar
I'm ready to help with that too!
--Josh
