Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 08-09-2010, 06:49 PM   #1
Camaro_nut2001
Chevy Lover Till The End.
Camaro_nut2001's Avatar
Turn signal, Hazards screwed up
I traded around Sat. & wound up with a '93 Chevy Blazer Tahoe LT, 4.3L VORTEC, automatic 2wd. When I turn the marker or headlights on my turn signal indicator's light up on the dash. Also, if I pull the turn signal lever down to go left or push it up to go right the Hazards start flashing. Turn it back and they stop. What could be causing this?
1969 Chevy SWB Big Block - Under the knife as of 12/26/2011
1989 Chevy Silverado, 4X4 - Daily Driver
1996 Chevy Suburban K1500 - 4-Wheeler, Campin Truck
1968 Chevrolet Impala Sport Coupe - 327/350hp, TH400, all original.
Members I've met: BamaBaxter,
My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=500359
Camaro_nut2001 is offline   Reply With Quote
Old 08-10-2010, 08:04 AM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Turn signal, Hazards screwed up
have you checked your bulbs yet?
Old 08-10-2010, 12:42 PM   #3
Camaro_nut2001
Yep I checked all those first off. I'm going to remove the pigtail for trailer hookup tonight. Thanks for the help.
Old 08-12-2010, 10:32 PM   #4
Nedwinters
I am having the same problem on my 65'. Did removing the pig tail work?
Nedwinters is offline   Reply With Quote
Old 08-12-2010, 10:34 PM   #5
ed70
is very serious
ed70's Avatar
on 93s there is a bulb that looks exactly like the one that is supposed to be there and it isnt... a look a like... i had the wrong bulbs in mine and it kept doing that and blew fuses
1967 C-10 2wd fleetside LB 350 4spd (dads) - sold
1970 C-10 2wd fleetside LB 307 700r4 - sold
1969 C-10 2wd fleetside LB 327 3spd - sold
1969 C-10 2wd fleetside LB 350 th350 - sold
1967 C-10 2wd fleetside LB 250 th400 -project in progress
Chevrolet=one who is dignified enough to expect every occasion is a special one and sees it fit to wear a bow tie... may others come under dressed.
ed70 is offline   Reply With Quote
Old 08-12-2010, 11:07 PM   #6
Nedwinters
Actually, when I went to Autozone to get new bulbs, the guy behind the counter tried to give me a bulb that was different than the one I took out....hmmm!??Thanks. I will check it out.
Old 08-12-2010, 11:14 PM   #7
ed70
is very serious
ed70's Avatar
they look like the same exact bulb just diffrent part number... i think it has to do with how much power it pulls through...
Old 08-12-2010, 11:15 PM   #8
ed70
is very serious
ed70's Avatar
i would aslo try th circuit boards for the tails... there not that expensive and i have had problems with them before... just a thought
Old 08-18-2010, 12:08 AM   #9
Camaro_nut2001
Well yes & no. I have blinkers now on both sides but the turn signal indicators still light up when I turn the headlights on. I'm going to check into that bulb issue as I've heard that somewhere else but can't remember what it was on.
turn hazard blinkers
