Junior Member
Do Dana 60 8 lug and 6 lug gears interchange?
I have both in disrepair and wonder if I can use the gears out of the 6 lug rearend in the 8 lug?
71 Suburban 350/700R4 Project Trixie 72 CHEVY,Highlander,SWB,396,T400 |
Re: Do Dana 60 8 lug and 6 lug gears interchange?
the rear ends would have to be the same size and make to do a gear swap
I was hooked on these trucks since 1982 when I drove my budys fathers 1968 Custum GMC 396 automatic dana 60 rear with a power lock diff what a ride more fun then we will we can ever tell!! |
If they have the same spine count, they can swap. Dana 60 have had a few different spline count through the years. The housings are the same, the carriers may be different. Of course front D60 parts do not swap with rear D60 parts.
'70 GMC C1500 LWB Power disc brakes. WooHoo! Posi 6 Lug Dana 60 |
Yes, they are the same. Both 30 spline. The ring and pinion would swap regardless, only the side gears are different for different shaft splines. Also, front and rear D60 carriers and gears are the same unless you are talking about a reverse rotation front axle.
Tim |
Junior Member
Both of these are rear ends. The rod that holds the spider gears sheared off in the 8 lug and wanted to have a shop replace with the 6 lug gears. The 6 lug needs and new axel and I can not find one.
#6 | |
