Old 08-09-2010, 08:19 PM   #1
old cruiser
old cruiser's Avatar
230 3 speed behind 283 ?
Hi all I,ve hunted all thru this forum and found that the bell housing and flywheel from the 230 should fit the 283. What I want to know is the original 3 speed up to the task of the 283 or are they one and the same ?
Would like to keep 230 but mines not rebuildable and the,re as rare as hens teeth over here but have more chance of getting hold of a 283, just looking at my options.
thanks in advance
old cruiser is offline   Reply With Quote
Old 08-10-2010, 12:27 AM   #2
Captainfab
60-66 Nut
Re: 230 3 speed behind 283 ?
That 3 speed should hold up behind a 283, or most any small block, as long as it isn't wore out, and you don't hammer on it hard.
Old 08-10-2010, 04:05 AM   #3
old cruiser
Thanks captain
Old 08-10-2010, 04:25 PM   #4
oldblu65
oldblu65's Avatar
Cruiser , I swapped my 230 for a 283 about 2 years ago using most of the original 230 parts ( i.e.- bellhousing , tranny , etc. ) and have had no problems in limited driving . If the tranny is in decent shape and you don't hammer it , it should be okay . Good luck !
oldblu65 is offline   Reply With Quote
Old 08-10-2010, 07:26 PM   #5
raycow
The same gearbox was used on the 230 and 283, so you shouldn't have any problems if it is in good shape now. Just don't put foot-wide tires on the rear and dump the clutch.
Ray
raycow is offline   Reply With Quote
Old 08-11-2010, 03:21 AM   #6
old cruiser
Thanks guys thats given me another option for engine replacement now the hunt begins
