08-09-2010, 08:26 PM | #1 |
throttle linkage
put a new intake and carb on my truck with some other goodies and now havin some issues adapting my 600 edelbrock electric choke to the stock throttle bar(linkage). i was hopin to get some insight before i start cutting and fabbing if theres an easier way. thanks
08-09-2010, 09:27 PM | #2 |
Re: throttle linkage
I did this to my truck, I will go take a picture and post it for you. I just sanded down the end of the rod a tiny bit & it worked perfectly. really was a a 10min simple job.
08-09-2010, 10:26 PM | #3 |
ok. thanks. ive seen where a lot of people are using heim joints but i dont like the way they look because they stick out so far from the carb. but if i cant figure something out i may have to join the crowd.
08-09-2010, 10:34 PM | #4 |
Who's got steelies?
You can also enlarge the hole in the throttle arm to 1/4" and attach it like below:
1969 C10 LWB W/ 250 I6 & 3spd 1970 C10 with '67 small window cab, 68 front end, blue; 305/TH350, 3.08 limited slip rear end, manual brakes, power steering; & 4-wheel drums-My daily driver. 1975 Chevelle Malibu Classic Coupe 350/th350 mint green 1970 C20 Suburban 350/700R4 4.10 gearing green & white 1978 Big 10 Silverado 350/th350, working ac, 2 tone blue-My summer daily driver 1983 GMC 1500 Sierra 305/SM465 2.73 rear end How to add a trip odometer to your 67-72 stock speedometer How to rebuild your Q-Jet My Truck Page My Youtube Channel |
08-10-2010, 12:22 AM | #5 |
Here ya go, pretty much the same as above, just flipped around so I did'nt have the extra rod end sticking out over the intake.
08-10-2010, 07:36 AM | #6 |
its all about the +6 inches
thats what I've always done too, hog out the hole.
08-10-2010, 07:53 AM | #7 |
This comes up often. You can hack it or purchase the correct piece from Edelbrock. Click on the link below, scroll down to my post, and click on that link.
http://67-72chevytrucks.com/vboard/s...d.php?t=361629 I sure would hate to have a hack job lock up at wide open throttle.
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
