08-09-2010, 11:30 PM | #1 |
What is this?
~~'71 GMC shortbed. Recently, 2007 Mazda 3 hatchback. Last edited by 71GMC71; 08-09-2010 at 11:39 PM. |
08-09-2010, 11:40 PM | #2 |
Re: What is this?
The button that releases the oil slick or smoke screen?
1972 C10 LWB, 350/350 Deconstruction began 5/2009, mostly completed restoration, 5/2017 |
08-09-2010, 11:43 PM | #3 |
Kill Bill...et
Re: What is this?
Looks like a light. Maybe a SES light (if you have a later model engine) is there anything running to the back of it?
08-09-2010, 11:55 PM | #4 |
Re: What is this?
if there is an alarm in there it looks like a glass breakage sensor.
_____________________________________________ 1971 Chev C-10 SWB CST 2008 Chev 1500 Crew Cab LTZ 2010 VW EOS 2007 Harley Davidson Nighttrain |
08-10-2010, 02:12 PM | #5 | ||
Re: What is this?
And theres no alarm on the truck :0
~~'71 GMC shortbed. Recently, 2007 Mazda 3 hatchback. |
08-10-2010, 02:23 PM | #6 |
Re: What is this?
That is where you plug in your flux capicator.
If it is a factory flux capicator connector you should see 4z14cp - z14 "Flux Capicator" on your SPID.
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
08-10-2010, 03:00 PM | #7 |
Re: What is this?
it might be your muffler bearing sensor get behind the dash and trace the wires it'll give you a good idea.
J.T. 1972 SWB 4X4 on 35"s with 6" lift all around 3/4 ton running gear with high steer and 4.88s 350/th350. SOON TO BE DONE:2" higher in front 37"s,LSX Swap,Hugger Orange & White Paint Scheme,Air Conditioning,Power Windows & Locks,Complete Gauge Kit,Tank Relocation,Double Din Nav with full Audio System. My Build Thread http://67-72chevytrucks.com/vboard/s...=1#post4169140 |
08-10-2010, 03:22 PM | #8 |
Re: What is this?
i'd lay on my back and look up under the dasboard where it is mounted .. if no wires attached to it then it's nothing,if wires attached follow wires and see where they go to findout what it is hooked up to
08-10-2010, 03:53 PM | #9 |
Re: What is this?
So there shouldn't be anything sticking through the dash at that point, the only thing that should be behind that is possibly your middle speaker.r.
08-10-2010, 03:58 PM | #10 | |
Re: What is this?
You should look to see if you can buy a repop Mr. Fusion, I bet GMCPauls sells them.
Blayne |
08-10-2010, 05:55 PM | #11 |
20' Daredevil (Ret)
Re: What is this?
Kinda what I was thinking too....
08-10-2010, 08:38 PM | #12 |
Re: What is this?
I looked under and found wires, but they arnt going to anything.
08-10-2010, 08:59 PM | #13 |
Re: What is this?
Its a hole plug. The guy at the factory had too much to drink the nite before and drilled the hole in the wrong place.
JRBECK64 |
08-10-2010, 09:00 PM | #14 |
Rottenwood Garage Member
Re: What is this?
To achieve the 1.21 jigawhats!
2004 Chevrolet Suburban C1500 2001 Chevrolet 2500HD Crew 6.0 1999 Harley Davidson Electra Glide 1972 Chevrolet C-20 Custom Camper "Dump Truck" 1972 Chevrolet C-20 Suburban "Big Green" 1969 Chevrolet C-50 Wedge Hauler "Leonidis" 1966 C-10 2x4 short fleet 327 4 speed "Race Truck" 1952 Plymouth Cranbrook "Rican" (my grandfathers) 1931 Ford Model A Coupe "Black Beauty" 1930 Ford Model A truck "Club Cab" 4x4 Rottenwood Garage and Speed Shop.....where everything must be racy! It's not just a hobby..It's a LIFESTYLE!!! Thanks for nothing Barrett-Jackson You cant fix stupid or teach accountability! Time wasters, looky Lous and tire kickers are everywhere! Last edited by 72freak; 08-10-2010 at 09:00 PM. |
08-10-2010, 09:07 PM | #15 |
Man of Mini-Talents
Re: What is this?
When you turn it counter-clockwise, does the halo fade away?
Steve Project - Ruth 66 Skylark Project - Lola 60 Biscayne Project - Iron Ox 54 GMC 100 Project - Darth 69 Camaro |
08-10-2010, 09:09 PM | #16 |
Re: What is this?
That is a very rare factory option;-)!
