Old 08-10-2010, 06:29 PM   #1
TheApocalyptican
TheApocalyptican's Avatar
Radiator Fan shroud help
My 1990 4x4 350 Suburban with a/c, has what is obviously a non stock radiator. The shroud is pretty much jury rigged. I believe it is the original shroud. The radiator is 19 x 28.25 x 2.5 which according to lmc is a 4 row for the 454 from various years from 73 to 87 depending on options. The 2 piece shroud in the vehicle now, has clearly been cut in order to get it close to mounting right. What kind of shroud do I need to use to get everything to fit, and work correctly?
1995 Suburban K2500 454.....off road & towing
1999 Astro, work van
2006 Silverado 2wd 5.3 w/4.5" lift and 33s
TheApocalyptican is offline   Reply With Quote
Old 08-10-2010, 07:47 PM   #2
82swampthing
82swampthing's Avatar
Re: Radiator Fan shroud help
If your going to keep the radiator I would get a shroud for a 1990 454 suburban or better yet just install electric fans .
R.I.P gm 1908-1986
1982 chevy k20,350,sm465,np205,10bolt and 14bolt s.f
82swampthing is offline   Reply With Quote
Old 08-10-2010, 08:29 PM   #3
TheApocalyptican
Definitely keeping the radiator. Just had it completely renewed, so it's basically brand new. Electric fans are something I've considered. Just wanted to confirm that using a 90 454 shroud would actually work.
Old 08-10-2010, 09:12 PM   #4
Davidmichael
Davidmichael's Avatar
I would highly recommend a dual fan set up. It will help out your engine a whole lot. But the 454 shroud will work and it should fit over your bigger rad.
86 Suburban 2WD = rolled it and totaled it
83 LWB STD Cab 4x4 = went to the scrapper. Was my baby.
84 Suburban 2WD = stripped it/ scrapped it
81 8 foot bed made into a trailer
86 Suburban going to be made into a trailer
91 Suburban 4x4 = that's my baby
00 S10 Xtreme STD Cab
01 S10 ZR2
Davidmichael is offline   Reply With Quote
Old 08-10-2010, 09:59 PM   #5
TheApocalyptican
Probably going to do the ls1 fans. Just don't have the spare change right now to do it.
Old 06-17-2011, 02:23 AM   #6
TheApocalyptican
So I now have a 454 shroud, but I don't have the panel that goes between the radiator brackets to completely seal the shroud to the rad. Anyone have a source and/or part numbers for this?
Old 06-17-2011, 09:56 AM   #7
68Timber
I know the pieces fit
68Timber's Avatar
LMC should have a diagram.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
