Old 08-10-2010, 08:18 PM   #1
Buick455
Straight axle conversion from 88-98 Forum
I have a 1992 K1500 and a 1986 doner 4x4 silverado. What does it take to put the 1986 straight axle into the 1992?
Buick455 is offline   Reply With Quote
Old 08-10-2010, 11:32 PM   #2
64swb
64swb's Avatar
Re: Straight axle conversion from 88-98 Forum
i don't know if you plan on lifting the truck also, but i've used this kit before. http://www.sky-manufacturing.com/new...duct.php?id=64
then you if you are using the axle out of the 86 you would need to change to a passenger side drop transfer case. the best one to use if you plan on keeping your computer happy would be a np241 out of a 88-91 (73-87 bodystyle) fullzise blazer of suburban. for steering i converted to crossover steering at the same time and used the stock ifs steering box.
1978 Chevy C10, 1986 Chevy K20 'Burb, 1970 Chevelle, 1996 K2500 'Burb, 1977 Chevy K10, 1970 Ford F-250, 72 Ford F100 4x4, 1979 Chevy C30, 1982 Chevy C30, 1996 Chevy Dually 4x4 SAS, 1997 Chevy Tahoe, 1991 Ford F-350 cclb dually 4x4
64swb is offline   Reply With Quote
Old 08-11-2010, 08:37 AM   #3
Buick455
So if I use the 700R4 trans, transfer case, differential, springs, etc. out of the 1996 and purchase this kit this will work? What other parts would I need?
Old 08-11-2010, 12:01 PM   #4
propanemudtruck
Local Redneck Authority
propanemudtruck's Avatar
Did you mean taking the drivetrain out of the [B]86[B]?? Although you already have the donor truck, it might also be a good idea to look into using a ford solid D44 or D60 - you won't have any transfercase issues with your stock drivetrain then.
-Kevin
four on the floor feel the beat in your soul
movin to the rhythym pumpin til ya cant take no more
dance if you want to do what you came to
you cant ignore the feeling of that four on the floor
propanemudtruck is offline   Reply With Quote
Old 08-11-2010, 12:27 PM   #5
Buick455
I want to take the front and rear suspension and axles, trans and transfercase from the 1986 and put them in the 92 and use the 86 tires and wheels. All these components have been rebuilt and the tires are also new.
Old 08-11-2010, 12:46 PM   #6
propanemudtruck
I believe the trans you have is a 4L60 or 4L60E in the 92. You might need a manual trans computer for the truck to run right getting rid of the electronics in the tranny.
-Kevin
Old 08-11-2010, 08:03 PM   #7
Buick455
I either have the 700R4 or 4L60 (same trans) but I do not have the 4L60E.
So again if I use all the 86 parts how do I rout the exhaust on the 92 as if it was on the drivers side (due to the opposite drop transfer case) it would run into the fuel tank?
Old 08-11-2010, 08:46 PM   #8
Buick455
I found a site where a guy did the same conversion I want to do. He did not mention the exhaust though.
http://gmfullsize.com/forum/showthread.php?t=179653
