Old 08-10-2010, 08:19 PM   #1
coggonobrien
was there a 1968 k10 custom
going to be building my truck (taking a 1968 c20 long box, putting it on a 71 swb cst frame, with 1969 k5 drivertrain) and since its gonna be so far from original its stupid i was curious if there was a 1968 k10 custom in existence. considering doing the chrom accent trim. also this truck will get my 396bb.
thanks,
david
coggonobrien is offline   Reply With Quote
Old 08-10-2010, 09:27 PM   #2
haysonj
haysonj's Avatar
Re: was there a 1968 k10 custom
That is basically what I did. I used 69 swb frame and bed with the 72 front axle and a 73 14 bolt in the rear. I used a 69 CST cab and then put a lot of aftermarket accessories on it. FI 383 with a T400 and GV overdrive with 4:09 gears. Has a 4 in lift with 35 in tires
69 Chevy 4x4 383 Power
haysonj is offline   Reply With Quote
Old 08-10-2010, 09:39 PM   #3
coggonobrien
did you use blocks or new leaf springs? also whats the rim size/backspacing.
Thanks!
David
Old 08-10-2010, 09:47 PM   #4
haysonj
haysonj's Avatar
Thanks!
David
The rims are 12x16.5 and I believe the backspace is 6 in. I used a two in block and a 2 in shackle lift on the back. on the front it was all done with the spring brackets and shackles.
Old 08-10-2010, 10:12 PM   #5
coggonobrien
also do you have any pics you could email me? side profile, front, just varying angles?
thanks again
Old 08-10-2010, 10:48 PM   #6
haysonj
haysonj's Avatar
thanks again
If you go to my profile I have some pictures in an album there. I will try to upload some more tomorrow.
