Old 08-10-2010, 08:32 PM   #1
67chevylongbed
67chevylongbed's Avatar
LMC Exhaust kit fitment issues?
Has anyone with this kit had fitment issues? I was trying to install mine this afternoon and the angle on the first pipe is wrong so it won't mate up to the exhaust manifold. Anyone had this problem? I think I will have to have a muffler shop bend the pipe so it will fit correctly?
Eric
1967 C10 LWB SOLD....
1995 Ford F-250 4x4 Powerstroke, 342k
"Each generation goes further than the generation preceding it because it stands on the shoulders of that generation. You will have opportunities beyond anything we've ever known."
-Ronald Reagan
67chevylongbed is offline   Reply With Quote
Old 08-10-2010, 08:47 PM   #2
68gmsee
Active Member
68gmsee's Avatar
Re: LMC Exhaust kit fitment issues?
Yep, I had problems with the six cylinder exhaust kit. Had the wrong bends and angles. I was able to make it work by twisting and fighting with it and moving some mounts but it still ain't right.
I won't be buying any exhaust kits from them anymore. I'll just bite the bullet and pay my local guy the $250 plus dollars he wanted.
68gmsee is offline   Reply With Quote
Old 08-10-2010, 09:02 PM   #3
67chevylongbed
Well at least I'm not the only one Thanks for letting me know, I guess I'm just going to have to bend the pipes.
Eric
-Ronald Reagan
Old 08-10-2010, 09:04 PM   #4
Zoomin
Man of Mini-Talents
Zoomin's Avatar
You guys need to cut them some slack - they've only had 40 years to get it right.
Zoomin is offline   Reply With Quote
Old 08-10-2010, 11:03 PM   #5
mrein3
mrein3's Avatar
My V8, 4x4 kit fit like a glove. I highly recommend the kit to everybody who asks.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 08-10-2010, 11:09 PM   #6
Bus Ted Knuckle
Son of a gun
Bus Ted Knuckle's Avatar
I bet you can find a local place to make you custom exhaust for much cheaper than the kit will cost, and you won't have to mess with installing it.
BEATERS ARE NEATER
Bus Ted Knuckle is offline   Reply With Quote
Old 08-11-2010, 12:34 PM   #7
71meangreenc10
Its a Truck Thing......
71meangreenc10's Avatar
It will be close, I have the kit on my shortbed and I had to get one pipe adjusted, the price depends on where you are, in AZ where I was, I couldnt come close to LMC price, Midas wanted over 600 for complete exhaust, in TN I got a full exhaust for around 300 and that was the best I could find, plus being in a small town, you would think prices should be lower, nope, in NC where we currently are most exhaust places start at 250 and up.
Smitty
71 C10 283/3SPD Full Resto
71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599
70 C10 Suburban Former military GSA truck.
72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378
72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110
68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head
71 C30 Wrecker
71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck
68 GMC Long Stepside. They keep following me home
69 C30 Former Motor Home, Flat Bed time
70 G20 Red-E-Kamp Conversion "I'm your Boogy Van"
71meangreenc10 is offline   Reply With Quote
Old 08-11-2010, 01:14 PM   #8
Davetopay
My LWB K1500 has the dual kit and it appears to fit quite well. The tubing is amazingly thick, I doubt it will ever rust out....the turbo muffs and hangers are another story. I can't comment on how it was to install since the PO added it to the truck. As far as fit goes, the muffs are tucked up between the frame rails and the drive shaft and all the tubing stays up nice and high until it pokes out with the side exit behind the rear wheels. I assume the turbo muffs on it are the ones that came with the kit. They sound nice, no drone, but the lack of a balance pipe(tough to have on a 4x4) makes them a little bit "blatty". I can tell a real difference in their sound from when I got the truck almost 2 years ago. I assume there is some amount of fiberglass packing in there which has degraded with time and use. The front half was hooked up with some welded in bends to make it fit with the rams horn manifolds. (casting numbers come up as Corvette, don't know if it means anything) It looks like the kit would work well with a set of headers, but I haven't bothered because I have a 4spd and it would be a pain. I was thinking about some different muffs, but I don't NEED them now.
Davetopay is offline   Reply With Quote
Old 08-11-2010, 05:39 PM   #9
Tkmadone
I used the kit on my longbed 2wd v8 and it worked great! Half the price the muffler shops wanted to charge me locally.
Tkmadone is offline   Reply With Quote
Old 08-11-2010, 05:42 PM   #10
jamie72
jamie72's Avatar
just installed a kit on my 69, it fit great,really better than i exspected, sounds good too.
jamie72
72 BB cheyenne -- Restoration getting started..
member #807
http://www.myspace.com/whitetailobsession
www.antlertalk.com
jamie72 is offline   Reply With Quote
Old 08-11-2010, 05:49 PM   #11
cdowns
cdowns's Avatar
could b over the years somebody put different exhaust manifolds on an old truck and that is the misalignment issue
i've used a few of the LMC exhaust kits never had a problewm they always fit great 4 my applocations
Old 08-11-2010, 06:20 PM   #12
67chevylongbed
The engine is an aftermarket motor, and the exhaust manifolds could be wrong. Here are some pics, is it the manifolds?
Eric
-Ronald Reagan
Old 08-11-2010, 06:42 PM   #13
bigsnookmaster
bigsnookmaster's Avatar
You need the ramshorn manifolds that turn back, instead of dumping straight down.
bigsnookmaster is offline   Reply With Quote
Old 08-11-2010, 06:48 PM   #14
jamie72
jamie72's Avatar
you have the 4x4 ramhorns.. you need the 2wd ramhorns
jamie72
member #807
www.antlertalk.com
Old 08-11-2010, 08:54 PM   #15
67chevylongbed
I did not know that, thanks for pointinf that out... I'll have to start looking on cl. Any other places I should look?
Eric
-Ronald Reagan
Old 08-11-2010, 09:05 PM   #16
Chevydude56
Chevydude56's Avatar
You can look in the parts for sale section on this forum.
I think you can buy new aftermarket at most parts stores
1967 Suburban 292 3spd
1964 Chevy II wagon
1971 Monte Carlo 402BB
1964 Cadillac series 62 2dr
1964 Bonneville 2dr/ht
1967 GTO
1978 Chevy Van 30
1989 R30 Crew Dually Bonus Cab
Chevydude56 is offline   Reply With Quote
Old 08-11-2010, 09:13 PM   #17
67chevylongbed
Thanks, I will check out the for sale section, and I saw that LMC sells them too.
Eric
-Ronald Reagan
Old 08-11-2010, 10:19 PM   #18
pat 70/71
pat 70/71's Avatar
Bought one for my six silly , didn't fit at all ! sent the wrong kit . anywho, never again. this is lmc. If anyone orders an exhaust from them, check it the minute you get it. returns are such a pain. cheers, Pat
pat 70/71 is offline   Reply With Quote
Old 08-12-2010, 11:05 PM   #19
67 k20 firetruck
67 k20 firetruck's Avatar
My exhaust on my 69 C20 w/ 350 fit like a glove (duals). The exhaust on my current ride 67 K20 with 292 is a nightmare. The driveshaft and exhaust rub 90% of the time the truck is running and nothing I can do to twist them, turn them to make it right. Both LMC.
67 k20 firetruck is offline   Reply With Quote
Old 02-26-2012, 10:05 PM   #20
rmccloye
rmccloye's Avatar
Question Re: LMC Exhaust kit fitment issues?
BIGSNOOKMASTER do both the manifolds need to be turn back or what. Because I was thinking about getting it for my truck and the driver side on mine is the tur back and my passenger side is straight down...
rmccloye is offline   Reply With Quote
