gas tank ideas
my truck is a 1960 and there are really no rear tank kits available that I can find so I ended up ordering the lmc kit for the 63-66 I set it in today and it just hangs way too low for my truck with the 5" drop considering I plan to bag it later. so I am back to the drawing board. so I need some suggestions on a rear frame mounted tank on a 60 that wont hang too low or some ideas for a bed mounted tank. please post ideas and pics. I thought about taking that tank and putting it in the bed hidden in a tool box or something to that effect.
Re: gas tank ideas
Take a look at post #8 of my build thread for my '65 SWB. I am unsure though if it will work on a 1960 frame design though.
http://67-72chevytrucks.com/vboard/s...d.php?t=363509 |
Re: gas tank ideas
You've discovered the drawback to the blazer tank, it hangs too low for most of us; otherwise it is great. Most other steel tanks that fit in the dimensions don't have enough capacity.
I really like lakeroadsters setup, also, check out his bed, the bed widening is very neat. John, did you move back the rearmost crossmember to fit this tank when you chopped for rollpan? I want 18-20 gallon capacity, and not too low hanging, so the dimensions will have to be increased in length. To do that, I have been thinking about removing the rearmost crossmember, using a class III trailer hitch plus additional bracing to maintain the rear frame integrity, and finding a steel or poly tank that fits. I may have to pay the $$ to have one custom built.
292 + TKO500 Last edited by Heater63; 08-11-2010 at 04:10 AM. |
#4 | |
Re: gas tank ideas
So if I was starting from scratch I would use a roll pan that doesn't have a license plate, use the hitch as the rear crossmember, and make the license plate as a removable piece that slides into the hitch receiver. It would be a tight fit and would likely require the roll pan to be installed after the bed is on the truck, but I think it is possible, especially if you get a custom made tank. I would also recommend buying a Mar-K roll pan. I bought mine from LMC, it is Taiwanese crap. I had to rework it to get it to fit flush with the fenders and I ended up modifying the rear fenders to get everything flush and smooth. And a final note: Tanks Inc. redesigned their 49-52 Chevy tanks to be 1" deeper. They are now 18 gallons, the tank I installed in my '65 is 16 gallons. Last edited by lakeroadster; 11-27-2010 at 11:53 AM. |
#5 | |
"Where were you in '62?"
![]() Join Date: Jul 2004
![]() Quote:
![]() http://67-72chevytrucks.com/vboard/s...d.php?t=321173 http://67-72chevytrucks.com/vboard/s...368988&page=20
PROJECT: "FULL METAL YELLOW JACKET" 1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck PROJECT: "FULL METAL YELLOW JACKET Build Thread What Are You Workin' On? - 1Bad62ChevyPickup PROJECT: "TYRANNORAMBLER REX" 1969 AMC Rambler American Nostalgia Pro/Street Youtube Channel: Father Son Projects Youtube Channel: 2TIMOTHY2FITHTEEN ![]() ![]() ![]() ![]() ![]() ![]() ![]() "North and South Carolina Folks Click Here!" (((( ~ I have Parts For Sale & Miscellaneous Stuff ~ )))) "Well being as there's no other place around the place, I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D. Last edited by 1Bad62Pro/Street; 08-11-2010 at 10:55 AM. |
Re: gas tank ideas
Thanks lakeroadster. After I posted I revisited your build and saw that you had fabbed a new rear cross piece. That is how I will proceed, put in a new rear plate, remove the factory crossmember, then find a tank that fits or have one built. Later in the build I will decide about roll pan vs bumper vs hitch with hidden reciever, etc
Mar-K is a 2 hour drive, I can actually go get pieces from them if needed, glad to hear they are good quality. I have been pleased with some Tri-Pro patch panels also. I appreciate all your posts, you have great ideas, nice to observe an engineer at play as we can all learn something from you.
292 + TKO500 Last edited by Heater63; 08-11-2010 at 07:05 PM. |
Re: gas tank ideas
anybody got a bed mounted tank or ideas on one?
Senior Enthusiast
Re: gas tank ideas
Here are some earlier threads on the topic for additional ideas:
http://67-72chevytrucks.com/vboard/s...highlight=tank http://67-72chevytrucks.com/vboard/s...highlight=tank http://67-72chevytrucks.com/vboard/s...highlight=tank |
60-66 Nut
![]() ![]() Join Date: Mar 2007
Re: gas tank ideas
There is a board vendor, Boyd's Welding that sells custom aluminum fuel tanks. I believe he has one for the '60-'62's. You can find him in the Vendors Marketplace.
Re: gas tank ideas
Thanks, I'll have to take a look. You think with all the 60-62 trucks being restored, they'd make a Aftermarket Fuel Tank. We stock RCI Race fuel cells where I work, will have to measure and see if I can make one of them fit.
Hell yeah!!!
Re: gas tank ideas
you can always try an early mustang gas tank. you just need to fab up some mounts at the rear to where your happy with the ground clearance.
Stock is good but custom is the sh*t! |
Re: gas tank ideas
A few years back you used to be able to find new old stock military blazer gas tanks for REALLY cheap on the web.
#13 |
Re: gas tank ideas
ok everybody stop what you are doing! boyd welding makes a tank for our truck! the 60-72 truck basicly have the same chassis with only some crossmember differences ,but boyd has modified his product to fit all of the trucks now. i just bought one 2 months ago and it fits perfect in my 66, even though his product still says 67-72.
http://www.boydwelding.com/TruckTanks.html
66 chevy shortbed fleetside 73 camaro 98 chevy pickup |
#14 |
Re: gas tank ideas
Needs to update his web page to 60-66, could probably sell more tanks
#15 | ||
Re: gas tank ideas
The other options being discussed in this thread however, with tanks that are at $200 or less, provide a much more cost effective solution for those of us doing budget builds that don't mind doing some fabrication / modifications to the frame. Last edited by lakeroadster; 11-28-2010 at 08:07 AM. |
#16 |
Senior Car Nut
![]() Join Date: Jan 2008
Re: gas tank ideas
my '60 service manual and my '63 service manual says the frame width is different at the rear, I can go measure my '61 and '66 tomorrow.
Larry |
#17 | |
60-66 Nut
Re: gas tank ideas
Yes the '60-'62 2wd frames are wider than the '63-'72 frames. I don't remember exactly how much but it's around 4 inches I believe. I know Boyd had some issues a while back with clearance issues on the shortbed trucks. And yes he did remedy that issue. The frames are basically the same from '63-'72, so yes a tank designatedfor a '67-'72 will fit in a '63-'66 frame. However I don't know if those tanks will fit the '60-'62 frames or not. There was a member here a while back that bought a custom made tank for his '60-'62. IIRC he got it from 'The Fuel Cell Guy' who is also a vendor here.
Power Steering Box Adapter Plates For Sale HERE Power Brake Booster Adapter Brackets For Sale '63-'66 HERE and '67-'72 HERE and '60-'62 HERE and "60-'62 with clutch HERE Rear Disc Brake Brackets For Sale. Impala SS calipers HERE Camaro Calipers HERE D52 Calipers HERE 6 Lug HERE Hydroboost Mounting Plates HERE Last edited by Captainfab; 08-31-2010 at 11:46 PM. |
#18 |
![]() Join Date: Feb 2009
Re: gas tank ideas
I had Boyd make a tank for my 62 and it was a perfect fit. I believe it is 23 gallons and it could have been more if I had wanted to add to the length. But the install was easy with a little drilling of a couple holes to match. I have not hooked up up electrically yet but have run the tubing and hooked it up to the fuel pump.
He was a pleasure to work with and I did it all over the phone and he also had the right sending units and floats. |
#19 |
Re: gas tank ideas
Fuel Cell Guy has a group buy going on now, Dave Boyd has a group buy starting next week. Both have very high praise on this board. Both are listed under the boards Classifieds, Vendors Marketplace
292 + TKO500 |
#20 |
Re: gas tank ideas
Another option is a 71-80 International Scout II fuel tank - I picked one up at a 4x4 swap meet for $70. It is 19 gallons and is a good "mock" fit behind the axle in my 66.
I have no photos to share - I'm moving the filler neck to the back of the tank so I can hide it behind my license plate (or so I think I am - until proven wrong ![]() |
#21 | |
60-66 Nut
Re: gas tank ideas
If that is a used tank with any indication of gas fumes inside, do not get any ignition source (flame or spark) near it. There are a few ways to weld or solder on used gas tanks. Regardless it can be extremely dangerous.
#22 |
Re: gas tank ideas
Tank will be purged with CO2 when I'm cutting / welding, plus, it has been sitting so long the fuel turned into varnish (about one gallon).
#23 |
60-66 Nut
Re: gas tank ideas
OK, I just wanted to be sure you were aware of the dangers of welding or soldering on used gas tanks. Sounds like you have a good plan......carry on
#24 | |
Re: gas tank ideas
![]() ![]() Thanks! ![]() |
