Old 08-10-2010, 11:38 PM   #1
WHITE-NOISE
WHITE-NOISE's Avatar
71 body on 68 frame questions
im in process of swapping my 71 k20 body onto the 68 k20 frame i have, my plans with this truck are to be competing in tuga truck pulls and i was lookin into about a 4inch lift. but alot of talkin with some buddys of mine that have built these trucks have told me that lifting a 68 truck is a nightmare... im wondering what is the problem with it is and what all im gonna have to do to make will, also im wanting to run 4 inch lift springs front and rear, no blocks.. thanks!!
WHITE-NOISE is offline   Reply With Quote
Old 08-11-2010, 10:28 PM   #2
WHITE-NOISE
Re: 71 body on 68 frame questions
bump...anyone????
Old 08-11-2010, 10:40 PM   #3
64swb
64swb's Avatar
im not completely sure but i think the 68 has narrower springs. any particular reason you are swapping to the older frame?
1978 Chevy C10, 1986 Chevy K20 'Burb, 1970 Chevelle, 1996 K2500 'Burb, 1977 Chevy K10, 1970 Ford F-250, 72 Ford F100 4x4, 1979 Chevy C30, 1982 Chevy C30, 1996 Chevy Dually 4x4 SAS, 1997 Chevy Tahoe, 1991 Ford F-350 cclb dually 4x4
64swb is offline   Reply With Quote
Old 08-11-2010, 10:41 PM   #4
msgross
msgross's Avatar
68 frame has longer rear springs, your better off with a shackle flip. Also the front axle is drum, closed knuckle so finding parts is near impossible. Other than that there are small differences but you shouldn't have much issue.
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 08-12-2010, 04:58 PM   #5
WHITE-NOISE
well im throwing a 14bolt and a 60 under it, and the frame on the 71 is in rough shape
Old 08-14-2010, 07:38 PM   #6
mudmizer
mudmizer's Avatar
Just the set up I have. 71 cab on a 68 frame with D60 and 14 bolt.
68 4x4, 454, 4 speed, disk brakes both ends,
Sold my 69 SS396 Elcamino when young & stupid
mudmizer is offline   Reply With Quote
Old 08-17-2010, 10:28 PM   #7
crazy87
Not really a big deal if the lift uses rear blocks. I assume you will be running traction bars so axle wrap due to the blocks will not be an issue. I run a 68 k-20 frame with the 69-72 4 inch lift (front springs and rear blocks) and it works fine. The 68 rear springs are 56" long and are wider at the eyes than the 69-72 versions.
crazy87 is offline   Reply With Quote
