1964-66 tilt column help
Im looking for a tilt column for my truck. I have a 1964 with a 3 on the tree but I want to move the shifter onto the floor and get rid of the tree column.
what tilt column will fit in my truck? I dont mind a little bit of custom fitting but what tilt column are you guys using????
Measure with a yard stick Mark with Chalk Cut with a torch ![]() Built it yourself, don't count on others to to do it for you or with you. It will never get done |
![]() Join Date: Jan 2010
Re: 1964-66 tilt column help
i'm going to try and find a van column so there is no ignition. might be hard to find a van column that came with a manual floor shift tho
Hollister, CA.
![]() Join Date: Sep 2006
Yeap, van column is your best bet overall for fit.
You could always fill the shifter hole.
John What the Heck is that ?? CURRENT BUILDS: 62 BurbMaster ![]() Other Builds: My '63 C-10,LWB,CC,BBW '06 HD StrAight Axle Swap Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build AMERICAN CUSTOMS & CLASSICS (831) 630-1965 www.ACCHOLLISTER.com ACC on FACEBOOK "Rest in Peace, Mom & Dad ... I will see you again someday!" |
I shoved a columm out of 73 - 87 C10. You need to bang down the collapsable shaft to keep your distance from steering wheel. I actually even switched over and used the key/ignition as well gaining the locking steering wheel for basic anti-theft.
60-66 Nut
![]() ![]() Join Date: Mar 2007
Yes the van columns are a good fit. One source for van columns that I discovered a couple years ago, is motorhomes. I have a neighbor that dismantles old neglected/abandoned motorhomes. Trouble is most of them have been Dodge chassis', but a couple have been GM chassis'
![]() Join Date: Apr 2001
does anyone have any detailed pics of the van tilt swap????
--Mike
63 C20 2WD, 230/SM420/4.11 73K 68 C30 dump truck, 327,SM425,4.56 66K original 68 C10 2WD SWB Stepper, 250/3-tree/3.73 66K.... Wifes 68 Buick Skylark Custom Conv., 350/TH400/2.56 In our family since '79 69 GMC 1500 SWB 2WD, 350/TH350/3.73 posi... 70 K10 SWB 4X4 4-sp,ps, pb, tilt, buckets, console, sliding back window (Need AC parts) WIP 72 Chevy K20 4x4 350/350/205/4.56 donor 72 Vette 350/M21/3.70 posi, triple black and super fast 84 Olds Cutlass Brougham 350/2004r/4.11 was Dad's |
